Question about HP Compaq Presario SR2150NX PC Desktop
I have a compaque with xp media center like this and somebody else entered the wrong program and installed windows xp from 2001. This system caused it to crash and I NEED some recovery disks to replace with the proper software. Can you Help me?
I found the codes within the computer and isolated its parameters overwriting the program and separated the second brain. After doing this I had some old restore disks to preform a software transfer. In doing so my computer came out to a factory style when we first bought the computer. Reformating is what I prefored afterwards. Now it is not stuck in the boot screen anymore and i have no more problems like blue screen of death when my computer has an error or failure to complete a task.
Posted on Oct 01, 2009
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
I want to fix a video problem XP media center 2005. Can I use the Repair ability (not recovery) from the reinstallation disk for just fixing media center and not affecting XP?
nah it doesnt work like that sadly.
most video problems are caused by the graphics adaptor driver.
click start
right click computer
click properties
click hardware tab
then device manager
everything in yellow means its a driver problem
it could also be you have the wrong driver installed or the settings are messed up. YOu have to reinstall the driver. use the cd that came with your graphics card or the one that came with your mainboard if you dont have a graphics card.
If you lost your cd the drivers can be downloaded from the manufactures web site.
Feb 26, 2010 | Microsoft Windows XP Media Center Edition...
Media center does not work on my windows xp
You should reinstall it using the installation cd because there is no downloads on the net for this.
Feb 22, 2010 | Microsoft Windows XP Media Center Edition...
Media Center for Window XP, TV don't work.
Try reinstall windows. If this doesn't work you might have a conflict with your tv-tuner
Nov 02, 2009 | Microsoft Windows XP Home Edition
I'm having difficulty installing itunes over xp media center. it seems that both xp and itunes want to grap the cd drive. Any way out of this? Also I heard that xp media centre is cp pro with some add...
I am not quite sure what you mean by saying that the programs want to grab the cd drive. Neither program should be using the cd/dvd drive unless you are using it, neither program has sole use of it. Could you clarify if you are getting an error during the installation?
No you can't install XP Pro and use the same product key that you have with Media Center. You need to purchase XP Pro if you want to install it and use the product key that comes in the packaging.
Sep 24, 2009 | Microsoft Windows XP Media Center Edition...
Windows xp media center says has encountered problem needs to clo
Well I would think back to when you started having the Media center problems, and did you make ANY new software installs just before the problem started? If so remove the newly installed program, or try to use "System Restore" to restore your system to a time just before you started having the problems. If this does not work, please post the EXACT wording of the error, eg: "fault in module..." "called from...." or make a screen capture or the error window expanded with all info showing.
Apr 10, 2009 | Microsoft Windows XP Media Center Edition...
Windows xp media center error occurs when trying to record programs
When that happens you usually need to backup your data, and reinstall the system to fix Windows corrupted files.
Try first doing a system restore to the most recent date before you started having the problem. If system files are damaged this will not help.
The media center is part of the WMC operative system. You can also reinstall media center alone using add remove programs, then Add remove windows components. Often that does not work, and you need to use a Windows MCE setup disk to fix the problem.
Apr 03, 2009 | Microsoft Windows XP Media Center Edition...
I need to reinstall XP media center on my Gateway PC
If you know somebody that has the same operating system disc (Windows XP Media Center Edition) you can use their CD to reinstall Windows and just use your product code number on your PC box.
Mar 15, 2009 | Computers & Internet
Major HP crash
i think you got the wrong disks man, nothing to do with the motherboard.
a clean installation
it is recommended to this service at least
once every 8 months, it wipes all your hard
drive from data, programs, bugs, errors and viruses
this will 100% solve your problem guaranteed.
for xp, insert the xp installation disk
restart the computer and a message will
come up asking to press any key to boot
from cd. once you do that "i mean you press a key"
then a blue screen will load then asks you
to press Enter to install xp.
1. press enter
2. select the partion and press enter
3. select continue "it warns you to delete files"
4. select format "quick"
5. now let it do the rest and follow instructions
6. when the installation is finished you'll notice
its like new again, some computers will need
drivers which you can get from manufacturer
website. download and install them.
that's it but for a detailed information click here
Mar 08, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
HP Compaq Presario SR2150NX PC Desktop Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
