Question about HP Deskjet 5440 InkJet Photo Printer
My HP 5440 printer sat unused for several months. I replaced both ink cartridges and it will not print at all. I tried using the services to clean and align (anything) but it does nothing. The power light is on and the resume button blinks. When I click the resume button it goes off but still nothing prints. I've tried pulling the cords and plugging them back in and nothing works. What can I do?
SOURCE: HP Deskjet 1280 : The resume light keeps on blinking.
Can I get the reply now? I have a whole lot of documents waiting to be printed.
Posted on Oct 11, 2008
SOURCE: Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Posted on Oct 13, 2008
  • 14 Answers
SOURCE: HP deskjet 1120c printer does not print -light blinks
ok try to add a printer in your computer select local port and it should be USB and the USB cable should be plugged in the computer and select the brand to be HP and the model to be 990c click on next till the FINISH appears and after that the printer will print from the computer
Posted on Feb 23, 2009
  • 298 Answers
SOURCE: cartridge alignment
Put a teeny tiny bit of oil (3 in one on fingertip) all over the slide (chrome bar that you see looking into the printer from the front) and retry. Just a thin film, NOT enough to drip.
The self test and align 'scan and print' procedure is timing out.
Posted on Mar 27, 2009
  • 99 Answers
SOURCE: HP Inkjet 2200 is no longer printing yellow
need to put a new yellow printhead.
Posted on Aug 04, 2009
Check ink cartridge on right
Yes - if they are not used they will dry up and be unusable.
Unfortunate but you need to replace them.
For future ref - IF they will not be used in 4 - 6 months
pop them out and put scotch tape on the head where ink comes out
and that should keep them good for several months..
I have done that and close to a year later - was fine.
Hope this helps :)
Sep 30, 2012 | HP Photosmart C4180 All-In-One InkJet...
Need to clean head on my printer, and can't figure out how. HP PSC 1315 All-In-One InkJet Printer It isn't printing well and has been in a cold cabin in the mountains for the past 8 months.
Just change the ink cartridges - the print heads are built into the cartridges on this printer. If it sat unused for 8 months, then probably some ink dried in the tiny holes and clogged them. While it might be possible to dissolve it with distilled water, I haven't had very good luck with that. It would be simpler to just put in new cartridges.
Jun 08, 2011 | HP PSC 1315 All-In-One InkJet Printer
Depending on the age of the printer, the service staion may need to be cleaned. The service station is where the cartridges "park" when they are not in use. Over time ink can collect in this area and therefore the ink cartridges do not get a thorough cleaning. I would go to HP's website and look for cleaning instructions for your printer model. Hope this helps
Sep 30, 2010 | HP Deskjet 5440 InkJet Photo Printer
My hp officejet 9130 will not print in color.
Try runing the printer test and see if colors print. If they don't your color cartridge is cloged. You can try to set the print head(copper strip on bottom of cartridge) on a damp paper towel for a while to try and unclog the head. You should see the colors on the towel. Dry head off and try again. Hp uses water base ink and it will dry up after setting for awhile. The printer knows it has ink in the cartridge, because it will try to print, so it has to be the print head.
The print head has two lines of holes or jet for each color and if some of them are cloged, it will look striped or missing colors.
Mar 05, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Printer Dormant
change your printer cartridge.
Apr 03, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP deskjet 5440
Never use alcohol, instead use distilled water or just water...
Seems like your cartridge need to be changed, maybe is very old in production date and ink is no more so fluid.
Dec 18, 2007 | HP Deskjet 5440 InkJet Photo Printer
Cleaning the print head on my HP5440 printer?
Try cleaning the head of the cartrige with alcohol and a Q-tip, if this doesn't help you may have to buy a new one. Cartriges can dry up if they haven't been used for a while. Even though you refilled it, there could be some dry ink stuck in the head. Hold the Qtip with alcohol on the head for a bit and let it dry, reinstall it and then try printing again.
Nov 08, 2007 | HP Deskjet 5440 InkJet Photo Printer
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
HP Deskjet 5440 InkJet Photo Printer Logo
94 people viewed this question
Ben Johnson
