Question about SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry
I can't delete files from my 160 GB Simpletech hard drive and it is full, what should I do?
    President:
  • 1,187 Answers
Do a "disk cleanup"
Click on [My Computer]
Right-click on the External drive (D?)
Select [Properties]
In the [General] tab, click on [Disk Cleanup]
It will "scan" your drive, but not remove anything... alow it to complete the scan.
Look at the recommended list that appears and accept its findings.
This should remove non-essential files and leave your data intact.
Burn some of your data, especially video content to DVD (make at least two copies) ... then remove the data from your external hard drive.
You may want to purchase another (larger) external drive. You can use two of them or move your data to the new one.
Posted on Sep 30, 2009
Testimonial: "Thanks, it didn't work, at least now I know I need to get a new portable hard drive."
  • Just Gort
    Just Gort Sep 30, 2009
    One other thing
    Your external drive may have more than one partition.
    Right-click on the external drive icon and select [Properties]
    How much is "Used", "Free", "Total" ??
    If total is not close to 150GB, then do you have another drive letter, such as "E" or "F"??
Simpletech 250 GB External Harddrive won't backup 180GB . Says it is full.
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Jul 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
I've met space limit for my SimpleTech external drive even though my internal drive still has space and both are 250 GB. Are there SimpleTech programs taking up space and if so how much of that 250 GB...
Your internal drive is different than your external drive. If you put more files onto your SimpleTech drive, then that one is going to fill up faster. The best thing to do would be to go through your SimpleTech drive and delete anything that you don't need. I don't remember my SimpleTech drive coming with any software on the drive, but if it did, it didn't take up much space.
Aug 21, 2011 | SimpleTech Signature Mini 250GB External...
Can I delete files from my simpletech 250gb
while in windows go in to my computer locate the drive letter of the external hard drive right click your mouse button a box will open go to explore your contents will show you can then find the files folders that you want to delete highlight the file or fo0lder right click your mouse same box will open go to delete and confirm by clicking yes then empty your recycle bin ,,,,I hope this helped
Nov 10, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Have a simpletech portable drive300 gigs-worked fine with windows xp-new computer has windows 7-suddenly cannot access drive anymore-windows 7 sees the drive but says drive is inacessible
Hi ,
This is neo , When did the setup for win XP the file system would be FAT32 . FAT32 is not supported in windows7. You can format the external drive BUT note the files in the drive will be deleted.
Nov 01, 2010 | SimpleTech SimpleDrive 160 GB External USB...
I deleted files from my simpletech 120 gb and now no computers recognize or will open the drive? Do I need to reinstall drivers?
While deleting files your hard drive files also have been deleted so you just re install and try it your probleem may be solved
Aug 27, 2010 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
Deleted partition
sorry for ur loss
just for your information once u delete the partition the hard disk goes in a raw data format to create a new partition
the old data cannot be recovered in this format
u might as well create a new one
May 04, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Will not run on Mac
*Mac only supports FAT-32 filesystem.
you have to reformat your drive.
WARNING! This will delete all files on the drive
This will work! Please vote!
Apr 13, 2010 | SimpleTech (sti-u2f36/160) 160 GB Hard...
Files on device become ''read only'' locked
i) i think this type of behaviours speciall due to presence of spware, virus in your system, initially to perform a full system scan on your disk and make sure that this not repeating in near future ...
ii) after do this try to change its mode(read only) by right-click on the folder or file u want to use and at the bottom you have to uncheck read only.........
Thanking youy
M. Sridhar
Dec 29, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry Logo
529 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
