This is usually indicative of soemthing blocking the flow of water out of the soap tray, down the connecting pipe and in to the drum chamber.
The soap tray doesnt have any seals as water should just flow into the tray, wash out the soap / fabric softner, and then flow out the back of the tray and down the connecting pipe. When working correctly, there is no pressure or water back-up to cause the water to reach the front of the soap tray.
Take out the tray - your machine user manual will show you how, and check both the tray itself and the "hole" it slots in to for either a build up of solidified soap powder, or some other foreign object. If still leaking, remove the tray again and try to get your hand (a woman's or teenager's hand being smaller is best) down the large oulet at the back of the "hole" the tray slots in to to feel for a blockage.
Do have young children ? A washing machine soap tray is a great place to hide things !
Occasionally, if the smaller pipes that deliver hot and cold water to the tray come adrift, this can spray water at the front of the machine. This water then has only one real way out - via the soap tray "hole". Most often this will be the cold water pipe as this has higher water pressure to cope with. The only way to check this is to take the top of the machine off.
If after all of the above it still leaks, you'll either need to dismantle the machine enough to see the back of the soap tray "hole", connecting pipe and drum chamber for a better look for problems, or call an engineer.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
thanks that was helpful just a shame i can't find the instruction manual.
" - lindallake
just moved into a new house if you could possibly help i cant work out how to dry our clthes as it...
(More)
JUST MOVED INTO A NEW HOUSE IF YOU COULD POSSIBLY HELP I CANT WORK OUT HOW TO DRY OUR CLTHES AS IT IS A WASHER DRYER AND NO INSTRUCTIONS WERE IN THE PROPERTY HAVE TRIED SYMBOL IN WHICH I THOUGHT IT WAS ??
Hiya my grandfather think the problem is the motor, but it does not spin. it turns on, drains the...
(More)
Hiya my grandfather think the problem is the motor, but it does not spin. it turns on, drains the water but does not spin. it is not the load of clothes that is the problem, because we tried it without any clothes and it still would not work.
zanussi fls 1383w program cycle keeps clicking round and stops on A sometimes it works but mostly it...
(More)
zanussi fls 1383w program cycle keeps clicking round and stops on A sometimes it works but mostly it wont sometimes it spins dry but wont stay on set cycle
zanussi jetsystem 1200xc fj1254w - door interlock came on as soon as door was closed. will allow...
(More)
zanussi jetsystem 1200xc fj1254w - door interlock came on as soon as door was closed. will allow changes to programs etc but as soon as start is selected it just beeps & continues flashing (start button- 5th led across)
The LED display disappears and the cycle stops. I have to press the green start/pause button to...
(More)
The LED display disappears and the cycle stops. I have to press the green start/pause button to restart the cycle.
