Question about InFocus LP70+ Multimedia Projector
LP70+ shutting down randomly and now not at all
Infocus LP70+ projector started shutting down at random times. Then it wouldn't turn on, or for only a short period of time. Now it won't turn the bulb on, but it gets warm. Is it the bulb, power source, or other?
  • 2,237 Answers
There is a problem with the zero volt ground reference level. if you're good at soldering, try this:
1. Locate cap C105 on the power supply and then turn the board over to the solder side.
2. From the solder side, locate C105, pin 2.
3. Using Lead-free solder only, solder the 60mm length
of wire to C105, pin 2.
4. Fold the cable over the edge of the power supply and secure into place using RTV45, Loctite Tak Pak Instant Adhesive, or suitable substitute.
Connection to Main Controller ECA
1. Using Lead-free solder only, solder the 30mm length of cable assembly to C900, pin 1.
2. Fold the cable over the edge of the main controller ECA between the two connectors as shown then secure
into place using Loctite Tak Pak Instant Adhesive.
if this seems like too much, you can send it in to an infocus authorized service center. try AV Solutions ( www.avsolutionsny.com ). they're really good.
Posted on Oct 21, 2009
  • benooo May 17, 2011
    Just tried following your instructions, it seems that the C900 negative side is already grounded in my case. Would you still have the full technical report on this fix ?
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Posted on Dec 09, 2009
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
InFocus LP70 keeps shutting off
if the fans go off imediately too, it's the power supply. if the fans stay on, it's either the lamop, ballast, or colorwheel. either way, you may need to send it in to an infocus service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 14, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70
Have you tried another lamp? Sometimes thats your problem, but I've seen a several occasions that the a defective power supply causes this symptom. Do you see an image flicker before the projector shutsdown? I do have some spare parts for this projector.
I'm on Ebay - gtitubro if you want to contact me through there.
Sep 17, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Turns off unexpectedly
I have the same issue. With a LP70. I upgraded the Firmware + USB Drivers and I still have t he problem. Basically as soon as a source is detected the Bulb turn off. Help!
Jun 25, 2008 | InFocus LP70+ Multimedia Projector
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
Infocus Lp290 Will not stay on.
Check the area around the fan and make sure you have good airflow. Put a small fan near the unit and direct the air flow so it cools it and let us know.
Aug 26, 2007 | InFocus LP290 1100 Lumen XGA LCD Projector...
Lp70 projector Error message about Fans
I had a similar problem with an LP70. my fan was sticking.
So I opened bottom cover and pulled out fan cage, there are 2 fans.
you must know which fan not running.
If you found bad one remove paper label(yellow)
you can see 3 small holes.
using wd40 few drops to holes.
then manually turn using your finger cw and ccw few times
you can feel smooth turning now.
then relabeling to hole side.
reassemble unit.
power on.
Now you can enjoy with your projector.
Jul 18, 2007 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
430 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
