Question about Hotpoint WMA58 Front Load Washer
Bearings need replacing - Hotpoint WMA58 Front Load Washer
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Posted on May 27, 2010
Replace front wheel bearing 2009 Honda accord
Hello James.
I don't wish to insult you but replacing the front wheel bearing of a front wheel drive vehicle requires the sort of tool kit and skill level that if you need to ask how you do you do it you are unlikely to possess.
By the time a wheel bearing needs replacing it has been subjected to years of heat, cold and moisture and removing the bearing from the hub can be fraught with difficulties not covered by an average repair manual, difficulties which needs experience and equipment to overcome.
As if that isn't bad enough the work needed to clean and prepare the hub to accept the new bearing needs the realisation the assembly is a piece of precision equipment requiring very high standards if the replacement bearing is to have the best chance of returning a good life-span. This is also true of actually fitting the new bearing where if pressure isn't applied correctly it can be ruined in a second or have it's working life seriously shortened.
I suggest you ask an experienced someone else to fit the bearing this time while you observe.
Feb 08, 2015 | 2009 Honda Accord
Replace slide DPRS405EA0WW
you need the front 1/2 top bearing G.E. part # WE3M26,also the 4 drum bearing slides that are mounted on this bearing need to be purchased too as they do not come with the door bearing,you need 2 white slides ( Part # WE1M504) and 2 green slides, (Part# WE1M507)which can be purchased along with this bearing
Aug 20, 2012 | GE Dryers
I am trying to replace the passenger side hub and bearing,before i tear it down i need to know if the bearing is just pressed onto the new hub and then the whole assembly slides onto the splined end of the...
Hello texasjagfan: My name is Roger and I will help you. The front hub bearings are press out bearings and you will need a press in order to change them. You will need to remove the front spindle to gain access to the bearings.You also will need an alignment when finished replacing the front bearings. The rear bearings are a hub and bearing unit.
Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Aug 18, 2011 | 2003 Chrysler PT Cruiser
Front wheel bearings need replacement. At what cost?
wheel bearings are'nt that expensive. i would buy 4 bearings and replace all four on the truck. the cost of two or four labour should be the same. a mechanic should have it done for you. buy the bearings youself and let the mechanic do it for you. good luck
May 06, 2010 | 1999 GMC Suburban
Is there a reason for the bearings in a front loading machine to keep needing to be replaced
It could be that the new bearings are being fitted onto a worn drum shaft, this would soon cause the bearings to fail again.
If it has not been replaced, then it should be done so.
Jan 27, 2010 | Washing Machines
I get a vibration as im driving possible from the rear wheel
a) Wheel Balance.
b) Wheel Alignment
c) Wheel Bearing.
My best guess is a wheel bearing needing replacement. If there is only noise, then MAYBE repacking of bearings. However with vibrations, the wheel bearing(s) need to be replaced. Make sure you replace both the bearing and races as a set.
Let me know if this helped or if you need additional help.
Dec 09, 2009 | 1992 Plymouth Acclaim
Conrod bearings need to be replaced in the engine that is 3y engine model for hilux and i want to know whether any adjustments needs to be done after installing the bearings
If the bearings need replacing the crankshaft will need grinding. After the crank has been ground you will have to buy suitable main and conrod bearings EG: 10thou undersize.
After fitting new bearings to the reground crank no adjustment is necessary.
Jul 01, 2009 | 1987 Toyota Pickup
Front bearings can I replace? what tools do I need?
The caliper has to come off first,then the rotor. Examine the outer bearing first for cracking, pits,rust,etc., it may be OK. If you want to replace them , you need new seals too. The outer bearing races can be knocked out with a hammer & punch
Pack the new bearings with grease,install the seal with a hammer & 2x4.
To set the bearings:
Tighten the nut to 12 ft/lbs while rotating the wheel
Back off the nut dead loose
Tighten it finger tight
back it off to the first pin hole
This should leave .001--.008 thou. end play
Hope that's enough info!
Apr 26, 2009 | 2003 Chevrolet Silverado 1500
DANA 35 BEARING REPLACE
If you are going to change one of the pinion bearings you really need to replace both since you will have the pinion shaft out anyway. At the same time you will need to replace the crush sleeve to set the proper load on the pinion bearings. Your Chrysler dealer should have the crush sleeve in stock. The bearings you can just cross reference to another bearing by using the old numbers off the race and bearing. Good luck.
Mar 07, 2009 | 1998 Jeep Grand Cherokee
Hotpoint WMA58 Front Load Washer Logo
286 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
