Question about Shure T2/58 Handheld Transmitter with SM58 Microphone
Intermittant signal, only works if I hit the head end and that only sorts the problem for a very short space of time?
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
The microphone will need repaired. Contact Shure.
Posted on Oct 08, 2010
2007 Mini Cooper convertible, stereo signal got worse and now can't listen to the radio, other functions still work. Have changed aerial and still no change? Any clues??
some sort of bad connection inside the radios socket
or bad coax
check the antenna with an ohm meter
to see if the coax is shorted out
and also that there is continutity between the center pin of the coax radio plug and the antenna
you can demount the radio and stick a bit of wire in as a quick test
if you get the signal then its something coax related
if not its something to do with the front end of the radios reciever circuit
and you need a radio engineer that fixes car radios and cb etc
they will make it work for sure
i could in ten mins flat ...possibly a transistor has failed
or a bad connection as it comes and goes ...
Dec 04, 2014 | 2007 Mini Cooper Convertible
Ativa lcd monitor
i think there is a problem with the power on the pc. if you can unplug the lead to the monitor and it works fine. but on the pc will not work, mouse can be connected. the graphics card could be the fault, it could be shorting out and making the power fail. this can damage the psu at the same time if not sorted.
Jun 29, 2017 | Computers & Internet
Giving the code E.27
E27 Open Throttle Switch Signal here is a list of all codes E12 No Distributor Reference Signal E13 Oxygen Sensor Not Ready E14 Shorted Coolant Sensor E15 Open Coolant Sensor E16 Generator Voltage Out of Range E19 Shorted Fuel Pump Circuit E20 Open Fuel Pump Circuit E21 Shorted Throttle Position Sensor E22 Open Throttle Position Sensor E23 EST Signal Problem E24 Speed Sensor Circuit Problem E26 Shorted Throttle Switch Circuit E27 Open Throttle Switch Signal E30 ISC RPM Out Of Range E31 Shorted MAP Sensor Signal E32 Open MAP Sensor Signal E34 MAP Sensor Signal Out Of Range E37 Shorted MAT Sensor Signal E38 Open MAT Sensor Signal E39 VCC Engagement Problem E40 Power Steering Pressure Switch Signal E41 Cam Sensor Signal Problem E44 Oxygen Sensor Signal Lean E45 Oxygen Sensor Signal Rich E47 BCM to PCM/ECM Data Problem E48 EGR System Problem E52 PCM/ECM Memory Reset E53 Distributor Signal Interrupt E55 Closed Throttle Angle Out of Range E58 Pass Key Control Problem E60 Cruise - Not In Drive E61 Cruise - Vent Solenoid Problem E62 Cruise - Vacuum Solenoid Problem E63 Cruise - Set Speed vs Vehicle Speed E64 Cruise - Acceleration Too High E65 Cruise - Servo Position Signal Problem E66 Cruise - Engine RPM Too High E67 Cruise - Switch Shorted E68 Cruise - Command Problem E70 Intermittent TPS E71 Intermittent MAP E73 Intermittent Coolant Sensor E74 Intermittent MAT Sensor Signal E75 Intermittent VSS Signal E80 Fuel System Rich E85 Idle Throttle Angle Too High E90 Cruise - VCC Brake Switch Signal Problem E91 Cruise - PRNDL Switch Problem E92 Heated Windshield Request Problem E96 Torque Converter Overstress E97 P/N To D/R Engagement Problem E98 P/N To D/R ISC Engaged Problem E99 Cruise - Servo Apply Problem
Jul 31, 2013 | 1992 Cadillac DeVille
Code B0100
Hi there:
DTC B0100 - Electronic Front End Sensor 1 Performance
The following can cause an intermittent condition:
  • A short between the front end sensor signal and low reference circuits
  • High or low resistance in the front end sensor signal and low reference circuits
  • Inspect the front end sensor signal and low reference circuits carefully for cutting and/or chafing
  • Verify that the correct front end sensor is installed in the vehicle
Hope helps.
Jun 03, 2013 | 2006 Pontiac Torrent
I have no rear lights. There seems to be a short possibly. when you step on the brakes or have the head lights on the turn signals blink fast. All the front lights work fine just no rear lights.
the bulbs that are used are a plug-in style and you need to take them out and check the ends of each bulb. I had one doing the same thing, and the bulb was good, which didn't make sense until I inspected the plug-in, which had a burnt end causing the bulbs to only receive power intermittently. Check yours and you may just be looking at the same thing.
Apr 15, 2011 | 2006 Jeep Wrangler
My daughters subaru impreza, brake lights not working intermittently. Had switch replaced three times where she lives. Works for a week or two then quits working again. My husband brought it home, it...
It's not the brake switch. the lights for the brakes, turn signal, headlights, and parking all go to the turn signal switch/ multi fuction switch. this is wher your problem is probably coming from
Jun 17, 2010 | 2004 Subaru Impreza
Hit a bump in the road , speedometer , tact ,went dead
Wonder about your stoplight, taillight? Most of that stuff runs off the accessories fuse. Check that fuse to see if it is blown. If it is, replace it and see what happens. If it blows immediatly, you've got a dead short somewhere. If it stays there, you may have an intermittent short. The intermittant short is a bear to find because it's tough to fix a problem when it ain't there. Electrical problems are always difficult and this about the best information I can give you. It's a starting point.
Good Luck
Steve
May 27, 2010 | 2008 Harley Davidson FLHX Street Glide
When turning on left turn signal, the flashers come on, when turning right only the right flasher works.Automatic door locks work intermittently
you have two problems the flashers are shorted. I would check the wire harness at rear off the truck. Possibly a trailer light harness has shorted at the plug most of these can be taken out of the harness and the two ends will plug together without the trailer plug.
Mar 07, 2009 | 2003 GMC Sierra 1500
Speakers tend to go in and out
absolutely.. grounds and scrubbed wires t o ground (shorts) intermittent will cause all you are experiencing
Nov 24, 2008 | 1999 Oldsmobile Alero
Electrical Problem
check ignition switch and wirring , may have a short. had similar problem on 84 ultra wirring at switch had shorted out on frame
Oct 09, 2008 | Harley Davidson Harley-Davidson Motorcycle...
74 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
