Question about Quintum Tenor DX2060 (501-0122-00) Networking Switch
Quintum dx 2030
i need help to configure a dx 2030 for voip termination. calls are coming from switch and terminate to e1 gsm gateway.
regards
2 Suggested Answers
SOURCE: I nees to setup Quintum
Command line for termination A800 (Quantum)
Config unit 1# online 1
Config sys# mindn 10
Config sys# maxdn 20
Config pstntg 1# pass 0
Config pstntg 1# cassig 6
Config pstntg 1# super 3
Config pstntg 1# lamp 1 country code (91)
Config pstntg 1# Answerdel 120
Config pstntg 1# lamp 1 9101 01
Config pstntg 1# dis 1 a (ALL - ports)
Config pstntg 1# ena 1 a (ALL – ports)
Config gkadmin allow 1# ip xxx.xxx.xxx.xxx (GW ip + switch-ip)
Config dsp# voice 81 (for g723) voice 68 for (G729)
Config# submit
Local information
Name of this zone Hello
Country selection Canada
Local country code country code (91)
International prefix country code (91)
Hop-off PBX Numbers
91 public
9101 01 public
This configuration for termenation
Posted on Dec 04, 2008
I need quintum axt2400 support
In case you need support from outside (remote location) for fine tuning you tenors just provide me the IP Address and Password via mail and, or chat; contact me as bdheeman (at) gmail (dot) com.
Dec 29, 2012 | Quintum Tenor AXT2400 (501014800) VoIP...
NEED QUINTUM PASSWORD RESETTING
The detailed description of Configuring Terminal Software/Assigning IP address to Tenor DX is given below.If you need only RESETTING GOTO STEP 18.
1.From your PC, click on Start> Programs> Accessories> Communications> HyperTerminal. The Connection Description is displayed.
2.Enter a connection name (i.e., name for each unit such as Tenor DX 1 and click Ok.
3.Choose the connection port on your PC from the Connect Using drop down list box (i.e., Direct to Com1). Click Ok. The Com1 Properties window will be displayed. See Figure 3.
4.From the Bits Per Second drop down list box, choose 38400.
5.From the Data Bits drop down list box, choose 8.
6.From the Parity drop down list box, choose None.
7.From the Stop bits drop down list box, choose 1.
8.From the Flow control drop down list box, choose None. Click Ok. A connection to the Tenor unit is established.
9.Click on Call>Call. A connection to the unit will be established. The login prompt appears.
10.Enter a login name. The default login name is admin.
11.Enter a password. The default password is admin. (Once you are up and running, changing the password is a good idea for security purposes). Step through each of the following parameters and enter the correct values for your installation: IP address, Subnet Mask and Default Gateway.
12.At the Quintum prompt, type ei to reach the Ethernet prompt and then type config to change to the configuration mode.
13.To set the IP address, type set ipa followed by the IP address.
14.To set the Subnet Mask, type set subnetmask, followed by the subnet mask.
15.Type siprd to change to the Static IP Route Directory.
16.To set the Default Gateway IP, type change 1 g followed by the IP address for the default gateway IP.
17.Type submit.
18.Type maint to reach the maintenance mode and then mc. Type reset. A confirmation message will ask if you want to reset the unit. Type yes to reset the unit. The reboot enables the Tenor to incorporate the new settings.
19.Once the IP information is set, you are ready to configure the unit.
Jun 04, 2011 | Quintum Tenor DX2060 (501-0122-00)...
Hello sir i lost my tenor ax series gateway license file by doing reformat flash now i need license file how i can get?
http://www.quintum.com/
go to the link above and then go to the support tab then look for chat or telephone number and get a rep they can give you a new or temp license tell them it got lost and they will replace.
Jan 23, 2011 | Quintum Tenor AXT2400 (501014800) VoIP...
How to apply in quintum license file .pls tell me quickly sir
Ok, I would love to help,
Please respond to this using COMMENT or REPLY
I believe this is fixable
Jan 13, 2011 | Quintum Tenor AXT2400 (501014800) VoIP...
Hi how to resolve quintum ax series problems license hardware configuration mismatch is the problem
You need to request a new/updated License file from custspt@net.com
plz note that the quintum.com is net.com now.
Aug 23, 2010 | Quintum Tenor AXT2400 (501014800) VoIP...
E1 or T1 to pabx to router to softphone
Yes, configure second Cisco E1 port to simulate you telcom (network side) and connect it to PB, and first Cisco E1 to your telecom provider.
On Cisco router configure voice ports, and number manupilation, so you can catch any call and redirect it anywhere (Voip, Telco, PBX).
I tryed that with Ericcson, and it didn't work until connections where like these
telco <-> Cisco VoIP gateway (E1x2) <-> PBX
PBX's are not very flexible, Cisco is.
Jan 27, 2009 | Smart Modular 128MB SDRAM Module for Cisco...
Which Affordable VOIP Gateway to Buy?
contact me so that i can send you list of voip gateway
khap_termination@hotmail.com
Mar 30, 2008 | Quintum Tenor DX2048 (501012100) 2x10/100...
Unable to send calls out after a change in the IP address
I hope that you have solved this by now, but the only way to be certain about what exactly happened is by reading event log trace. Your Quintum Reseller should have this knowledge.
Aug 29, 2006 | Quintum TENOR 960 VoIP Terminal Server
Quintum Tenor DX2060 (501-0122-00) Networking Switch Logo
139 people viewed this question
Top Quintum Computers & Internet Experts
David Payne
David Payne
Are you a Quintum Computer and Internet Expert? Answer questions, earn points and help others
