Question about Canon EOS 500D / Digital Rebel T1i Digital Camera
Pictures blue and will not trnasfer
Took pictures with my cannon t1i ,they turned out blue and will not transfer.
Why the onbored flash on my cannon rebel t1i wont work
Take a look at the hot shoe rails as there is a pair of leaf spring contacts that have to touch the underside of the rails to allow the popup flash to work
Carefully prize them upwards with a micro screwdriver
Jul 28, 2015 | Cannon Cameras
How to transfer pictures from my cannon pc 1249 to computer
try again and do not turn camera on first .
Feb 16, 2015 | Cannon Cameras
Why has my camera stopped working on picture transfer
I use an SD card reader. Found one at Staples for about $20. It connects through USB.
Dec 05, 2014 | Cannon Cameras
What does "BUSY" mean on my Canon Rebel T1i, while I'm trying to upload pictures onto my computer?
It means that the transfer is in process. It's letting you know that you shouldn't turn off your camera - it is busy!
Apr 09, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
I am trying to transfer pictures from my Cannon EOS Rebel T1i to my Mac book and I can't get it to work
When you connect the camera to the Mac, you must have the camera powered ON. THe Mac will automatically recognize the camera and will open iTunes to download the pictures. IF this does not happen, you may have a bad cable or a bad USB port on the Macbook. Try a different cable, or try a different port. Good Luck.
Feb 27, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Shacking when driving in reverse and when making sharp turns
Probably you have a bad encoder motor on the trnasfer case. Try "thepartsladi" on eBay for OEM part, beware aftermarket! Also, make sure the transfer case is using only "blue" GM Auto-Trac II fluid. Change it twice after a week of driving if it is not "blue" fluid when first checking.
Sep 29, 2009 | 1999 Oldsmobile Bravada
How do i transfer pictures form my phone to the computer?
3 main ways would be 1: use the usb provided and driver sofware load it onto your computer and transfer it that way, 2: if your computer has bluetooth send it via that or, 3: if you have a sd card and an sd slot in your computer then slide it in and go to my computer and should come up as removable disk, you may need an adapter first. hope this works
Jun 05, 2009 | Sony Ericsson Z520a Cellular Phone
Canon EOS 500D / Digital Rebel T1i Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
