Test test !!! do not answer - Office Equipment & Supplies
    Guru:
  • 104 Answers
Xcvxcv
xcv
xc
v
xcv
Posted on Sep 30, 2009
HOW CAN I TEST IT
First, CREATE a test plan, then provide questions for the test, and possible answers (such as multiple choice answers). Then figure out how much (in points) that each question should be worth, in the final grade!
May 15, 2017 | Cell Phones
What Is The Scope Of Web Testing?
Scope of testing includes the proces of determining allthe features and functionalities for testing. So asking for general scope of web testing (and it is a VERY large sub-class) is not perfectly correct. If you could elaborate on your question a little bit then maybe it will be easier to answer.
Or I could forward you here . You can use the wisdom center and it should answer most of your questions, better than anyone else (probably).
Mar 04, 2017 | The Computers & Internet
How can i tell if my fuel pump is bad?
old post, but Ill answer this , as it seems most forums give bad advice. on this topic.
answer,. read the FSM , or alldata.com or suzuki pit stop plus
it shows 6 tests.
this car came with 2 diff. engines, G16b and J18.
and the tests are simular but data is different.
here are the tests in the FSM.
1: cranking pressure. 35 to 40 psi. this is a guess. no engine stated, so no real numbers... answered. only a guess.
2: running pressure (vac. drops it) drop about 6PSI running.
we now test the FPregular for proper reg. at 3 vacuum points. (a hand vacuum tool)
3: the shut test.
4: the leak down test.
5: the 4 tests for INJECTOR leak down tests. 1 by 1>
its really 8 tests.
now the shade tree test
fuel dont leak from rail, fitting cracked, cranking , pump dead
or lost 12vdc to pump cranking.
that be it, with no gauge. must DIY fail here if the fitting dribbles.
as dribble tests dont tell you if pressure is correct.
a carb can run on 0.1psi or gravity , only
but on EFI it takes, 28psi, min. (injectors makers rule , no mine)
Jun 25, 2014 | 2002 Suzuki Esteem
Ics 100 test answers
Take a look at these sites. That is, if you're willing to wait more than a minute for an answer to your question.
www.ceu-courses-free.com
www.fema-test-answers.com
www.ceu-sourses-free.com
Oct 19, 2013 | Computers & Internet
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Testing ratings
According to the Hitchhikers Guide to the Galaxy, the answer is always 42!
Feb 20, 2009 | Acer Computers & Internet
I have a maxtor 6L080M0 hard drive that has crashed The return code is 7 Is there any way to fix this problem.
If the following determines you have hard drive failure then you may have to purchase a new HD. Follow what is recommended from the manufacturer below. READ EVERYTHING.
According to Seagate the makers of Maxtor, you have a DiamondMax 10 (6L080M0). See below or click here
My internal hard drive may be defective, how can I test it?
Question
My internal hard disk drive may be defective, how can I test it?
How can I determine if the problem is with my system or with the hard drive?
It is necessary to run the SeaTools, SeaTools Enterprise, or SCSIMax diagnostic before contacting Technical Support 1.800.SEAGATE (1.800.732.4283) on an internal drive that may be defective.
Answer
For Seagate or Maxtor (or Quantum) ATA drives:
If this is a Seagate or Maxtor (or Quantum) ATA or SATA drive, please download the SeaTools for DOS diagnostic to test it. If the drive is failing, the tests in SeaTools for DOS will indicate as such.
If the BIOS does not recognize the drive or the drive does not spin please reference Answer ID: 48
The operating system will not recognize a drive that is not formatted and partitioned. If you need help with formatting:
  • Windows 9x and ME reference Answer ID: 3076
  • Windows 2000 Answer ID: 880
  • Windows XP Answer ID: 3361
  • Windows Vista Answer ID: 3844
  • Macintosh Answer ID: 492
    For Seagate SCSI drives:
    Please download the SeaTools Enterprise Edition diagnostic.
    For Maxtor (or Quantum) SCSI drives:
    Please download the SCSIMax diagnostic.
    SeaTools, SeaTools Enterprise, and SCSIMax will test your S.M.A.R.T-compliant ATA, SATA, or SCSI disk drive for media defects, perform a read test, physical head test and ensure the hard drive is functioning correctly.
    If all the tests pass (no trouble found), the problem remains elsewhere in your system. Reconfirm all settings for hard drive jumpers, cables, and ATA, SATA, or SCSI controllers, and disk operating system. Consult your host controller documentation or system manufacturer for assistance with SCSI termination or ATA / SATA controller capabilities.
  • Jul 04, 2008 | Computers & Internet
    20 people viewed this question
    jasbo
    jasbo
