Question about Sony STR-DA5300ES 7.1 Channels Receiver
Is there a website I can access to input all components in my audio video system by brand and model and get info on connecting all to my AV receiver?
SOURCE: trouble getting a picture with a source selector
The input on your television monitor must be set to view the composite with the S video cable. You will not be able to view the component video unless you also have component video outputs going from the input selector to the television. After you have done that, you will also have to change your television input from "video 2" to whatever input you used for the component video hookup.
Posted on Dec 30, 2006
  • 20 Answers
SOURCE: how do I get video input from one source and audio from another?
I am confused and might be overlooking something obvious here. SO PLEASE do not think I am being disrespectful! IF you have everything connected properly, then your television is a separate device, independent of your Sony STR. You should be able to watch the picture with the Sony STR turned OFF. In turn, you should be able to LISTEN to the Sony STR with the television turned off. Although it isn't a lot of fun, it might be best to DISCONNECT all the cables (not your speaker wire) and go through the process of reconnecting everything.
Posted on Jul 18, 2007
  • 1694 Answers
SOURCE: Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
Posted on Nov 18, 2007
SOURCE: Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Posted on Dec 11, 2008
i just hooked up my sony blue-ray to my samsung suround sound.but i cannot get the sound to work.
Posted on Dec 14, 2008
I am trying to wire my amp to my stereo receiver and I'm having a hell of a time. Does anyone have any suggestions?
Auto sound system ? / home stereo ? What is the year, make and model car and if a home system - What components are you trying to connect? Provide brands and models of *all* components.
Sep 19, 2015 | Audio Players & Recorders
How to connect to tv to tv with component cables
In order to connect an AV receiver to a TV using component cables (Red & White) you will need to connect the component cables to an available AUDIO "OUTPUT" on the TV (red to red and white to white). Then the other end of this same cable will be connected to an available AUDIO "INPUT" on the AV receiver. The TV (via the menu or setup button) may have to be set to where the audio signal is output to a home theater and not to the TV speakers. Once connected, the AV receiver should then be set to the Audio input used in order to listen to what the TV is showing on screen.
Jan 02, 2014 | Audio Players & Recorders
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
Just purchased a Panasonic DMT-350 with analog 7.1 out and hooked up to my Onkyo 989 but tried everything and i mean everything to get my rear surround to play but no luck....pleeeeeease help me.
Hi.
Connect the Panasonic to one of the AV inputs on the Onkyo. Use red white and yellow AV cables. Connect the output from the Panasonic to one of the five AV video inputs on the Onkyo (or use the DVD dedicated input in the Onkyo backpanel). I indicated this option using red arrows. You can use any of the AV inputs or the DVD input at the bottom. Just ensure you do not connect to an output at the back of the Onkyo.
Alternatively use component cables and optical audio input, as indicated using the blue arrows in picture below. Select source and listen surround from the Onkyo.
There are more options. In some case you may decide to connect the DVD video output to TV and the audio to the Onkyo.
Here a manual for the TX DS989.
Here the backpanel:
Dec 26, 2010 | Onkyo TX-DS989 Receiver
Can I connect component av cables "in" to my Yamaha RX-V365 and connect "out" to my TV and get both audio and video?
Receiver does support 3x component inputs and one component output. Both these can carry only video signal, not audio. So you have to connect audio separately, either stereo via analog 2x RCA connectors and digital SPDIC via optical (2x) or coaxial (1x) cable.
Feb 23, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
No... i need to see how to wire this thing up i moved and lost the manual
Solution 1) The antenna goes to the antenna jacks, the video audio inputs to the video audio input jacks, the speakers to the speaker jacks, etc.
Solution 2) Find a friend who knows a bit about home AV systems and ask him to help.
Solution 3) Post the details of the receiver model and what other components you have in your system.
Nov 15, 2009 | Pioneer Audio Players & Recorders
PSP2000 SONY GAME
no you cant... the t.v screen cant support the games of psp.
Mar 11, 2009 | Sony PSP (Piano Black)
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
Sony STR-DA5300ES 7.1 Channels Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
