Question about Broderbund PrintMaster Gold 16 for PC
IDAPI Error #2C01
When I tried to print already saved labels, I received this error....IDAPI Error #2C01 "Network Initialization Failed." I clicked OK and the labels printed anyway. However, I trying to create a new label and it won't allow me past choosing which size Avery Label. Therefore, I can't create any new labels.
  • 265 Answers
SOURCE: avery laser addressing labels l7160
What software are you using? I use Microsoft Word to print my Avery labels, and quite often have to tweak their templates by simply adjusting my margins on the page. I do a 'select all' and then add one tenth of an inch at a time until the proof sheet looks just right. If the labels are a bit off, you can also adjust the pitch in the label options dialoge.
Posted on Dec 18, 2007
  • 265 Answers
SOURCE: Avery DesignPro Error while initialising
Since DesignPro is readily available from Avery online, I'd suggest that you remove and re-install the latest version of it to start with. That should fix your problem.
CLICK HERE.
Posted on Mar 15, 2008
yakusacyber
  • 4 Answers
SOURCE: When I try to save a project as a pdf, I get a
I should know not what you use to convert PDF him ..... for suggestions of my own you should use a nitro PDF .... I use it more easily then been integrated into the Office Word and power point
Posted on Jun 02, 2010
  • 1833 Answers
SOURCE: when I make labels I select"start from scratch"
Install The Print Shop's special fonts when running the automated installation process to ensure all toolbars and documents appear correctly in the software. If you bypassed this option and wish to install it later, click your Windows Start menu and select "Control Panel." Open the fonts control panel. Click "File" in the top menu bar and select "Install New Font." A dialog box will open. Navigate to C:\Program Files\Common Files\Broderbund\Core Fonts and press "OK."
Adjust your computer's hardware acceleration feature if the Print Shop's layouts or fonts appear distorted or overlap each other. Quit the program. Right-click your Windows desktop and choose "Display Properties" from the pop-up menu. Click "Settings" and press "Advanced." Push "Troubleshoot." Slide the adjustment bar for hardware acceleration one notch to the left. Close the window and resume use of The Print Shop 20. If the program's layout still appears jumbled, repeat this step and slide the bar one more notch to the left, repeating until the layouts no longer appear jumbled.
Posted on Dec 11, 2010
SOURCE: Cannot print Create cards from American Greeting.
i can email cards, but cards will not print.
Posted on Jul 20, 2011
D7160
error 0xc05d1281 mean the ink system failure
try blow reset Solutions
Solution 1:
  • Press and hold the "*" key.
  • Press the "#" key and release both keys.
  • Display should say "Enter Special Key Combo"
  • Press and release in sequence the "1", "2" and "3" buttons.
  • Screen says "support" R0631M
  • Press and release the right arrow button until the display says "System Configuration Menu".
  • Press and release the "OK" button.
  • Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
  • Display should say "Hardware failure status: Clear. Press OK to clear".
  • Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  • Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. DO NOT TRY TO PRINT AT THIS STAGE.
  • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
  • Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Solution 2:
  • Press * and # at the same time
  • Press 1, 2, 3 and "support R0632M" should display
  • Press > and "information menu" should display
  • Press > and "configuration menu" should display
  • Press OK and "hardware failure status" should display
  • Press OK "failure status: clear". Press OK to clear
  • Press CANCEL
  • Press CANCEL
  • Press CANCEL
  • Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
  • If the error came back, do the sequence again and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
Solution 3 (thanks to a1224imac):
  • This same error started occurring on my printer and eventually it would constantly poweron and off.
  • Apparently some defective components were used in the construction of the logic board (see photo).
  • On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer).
  • I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents).
  • On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662.
  • If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Jul 22, 2014 | HP Photosmart D7160 InkJet Printer
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
I'm getting the following message on my HP Photosmart C6180. Ink system has failed. Unable to copy, receive faxes, or print. Error: 0xc18a0201
Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit.
Aug 23, 2011 | HP Photosmart C6180 All-In-One InkJet...
Error 16 turn printer off
Hi -
The error codes 16 means that you need to check the print head thermistor circuit during power-on. Printer initialization determined that the print head itself is not installed. Some cause of this is again the print head is not installed, the print head built-in thermistor element has failed, carrier cable is disconnected or is already damage, print head temperature detection circuit has failed.
Having said this, it is better to have the printer check by a qualified technician or your local service provider
Hope this helps,
Good Luck!
Feb 28, 2011 | Epson DFX-9000 Matrix Printer
Opened my printer espson dfx 9000 and im getting an error 16 how do i overcome this?
OPENED MY PRINTER EPSON DFX-9000 AM GETTING AN ERROR 16 HOW DO I OVERCOME THIS
Jul 23, 2010 | Epson DFX-9000 Matrix Printer
Ink sys has failed.error 0xc18a0101
This ais a possible fix Christina: Let us perform some steps to isolate the issue and find a fix for it.
Christina: Please perform the following steps and let me know the message that will be displayed on the printer.
Christina: A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
CustomerName: ok
CustomerName: screen says "support" R0631M
Christina: Fine.
Christina: 2. Press and release the right arrow button until the display says “System Configuration Menu”.
Christina: 3. Press and release the “OK” button.
Christina: 4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Christina: 5. Press and release the “OK” button.
Christina: 6. Display should say “Hardware failure status: Clear. Press OK to clear”.
CustomerName: yup
Christina: 7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
CustomerName: ok
Christina: 8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
CustomerName: ok
Christina: 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
CustomerName: done
Christina: Fine.
Christina: 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
CustomerName: done
Christina: 11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
CustomerName: made a buncha noise, and it didn't print a diagnostic page
Christina: Good.
Christina: Is the error message still being displayed on the printer?
CustomerName: nope
Christina: Good.
CustomerName: should I try to print something?
Christina: Let us print a self test page to check the functionality of the printer.
Christina: Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Apr 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
EPSON DFX-9000 ERROR CODE = OD and OB
error code OB turn off the printer, why?
Sep 17, 2008 | Epson DFX-9000 Matrix Printer
Savin Printer
There are initialization cards with printers. They look like credit cards or odd shaped key cards.
They need to be inserted into a slot reader on the machine to activate or reactivate them.
It should have come with the printer.
Feb 19, 2008 | Office Equipment & Supplies
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Broderbund PrintMaster Gold 16 for PC Logo
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
