Question about Tippmann 98 Custom Marker
I shoot 4-6 shoots and either the gun recocks and there is no air charge or it doesn't recock.
    Problem Solver:
  • 8 Answers
Clean it and get a full fill on your tank.
Posted on Dec 14, 2009
How to put the spring back in the handle of Arrow T50 Stapler?
Ref. recocking the spring handle in your Arrow T 50 Stapler
1. secure the stapler in a vise. You need three hands to recock the handle spring.
2. Using a notched tack lifter hand tool, with one hand holding the handle so as to expose the spring, place the notched tool against the spring arm and force it to the rear. it will now be under tension.
3. Wiggle the handle into position so that you can quickly insert the clevis pin. Once secured, let go your handle that is now under tension. Replace clevis ring.
4. Dry fire to test.
Sep 18, 2014 | Arrow Staple T50 3/8"" Monel stainless...
My airace framing air nail gun blows air when i try to shoot it
Look for an O ring kit,,many times the firing cap seal splits thus loss of air
Mar 30, 2013 | Air Tools & Compressors
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
I ahve owned my gun for many years and never had a problem but now when i pull the trigger the gun will go full auto and empty the hopper in less than ten seconds i have replaced the rear sear spring the...
The sear and pin can certainly "look" fine but still be a fraction off and let the marker loose. Also, you may notice that the pin on the sear is different than the others? Perhaps silver where the others are black?
My best advice at this point would be to check with a buddy who's willing to let you exchange the sear and pin and see if that's the problem, or check with a local airsmith who can try this for you and check for any other problems as well.
Play hard, play safe, play with honor!
8^)
Oct 15, 2010 | Tippmann 98 Custom Act Paintball Gun
My gun wont shoot. Ill **** it once and it will fire a dead shot then not recock
Time to lube (oil) the gun. A few drops of oil in the inlet hole (where you screw on your tank) should do and then dry fire the gun. If no luck you may need to tear down the gun and clean and lube the internals.
Here is your manual.
http://www.paintballadvisor.com/manuals/Tippmann%2098c%20manual.pdf
Oct 06, 2010 | Tippmann 98 Custom Act Paintball Gun
My alpha black paintball gun is shooting 1 to 5 then stopping.
Sounds like it needs to be oiled. A couple of drops in the small hole where your bottle screws on.
Replace bottle and dry fire to see if you got it. Cleaning is just as important. Internals need to be cleaned
and lubed often. I know it's late but hope it helps someone.
Jun 11, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Shoot no shoot
make sure that the filter in the back is clean you can pop the back cover off and clean it with water if it is dirty then the excess co2 gas that the gun gives off will not be able to excape the chamber and sensors inside the gun will not let if fire. This should work for you
Sep 01, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I have a film loading Nikon 35mm SLR, and I don't know how to set the self timer to take a picture.
Hi , to set camera in self timer , did you see thew swevil knob on right on front thats the self timer knob , recock the film to load new shoot slide down self timer , aim to the object or tri pod stand then push the shutter you can hear gear running in few sconds the shutter cutain will open for take picture automatically , you must run and hurry to make pose within the few second , thats all good luck.
Mar 18, 2008 | Cameras
Tippmann 98 Custom Marker Logo
156 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Tom Chichester
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
