Question about Intertherm P3RA-048K Air Conditioner
No flame signal
Red light is on steady, no yellow light on at all
  • electriciand May 11, 2010
    what type of unit is this? is it gas pilot or electric ignite?
  • 89 Answers
The system might be in emergenvy heat mode. If not t-stat wires bad or t-stat bad.
Posted on Oct 12, 2009
Connecting a new stereo with red for AC power, black for ground, Yellow for battery fuse wire. The car stereo wiring has orange, black, yellow but no red wire. it has 3 others as well
Orange is your steady power source and Yellow is your switched power source so your new stereo would connect Red to Yellow and Yellow to Orange in most cases but it is best to use a test light to check before making connections.
May 04, 2016 | AC Cars & Trucks
What does 3 flashes of the red light mean on an amana model ptc153a35ac ?
Here are your Amana flash codes:
Steady On - Normal
Off Controller Failure
1 System Lockout
2 Pressure Sw stuck closed
3 Pressure SW Stuck Open
4 Open - High Limit
5 Flame sense without gas valve
6 Open rollout or open Fuse
7 low flame signal
8 Check igniter or improper ground
continuous flashing - reversed AC polarity
Sep 11, 2014 | Heating & Cooling
Furnace wont light, fan stays on
A flame failure will cause a lock out of the burner. Cut all power for 30 seconds and try it again.
Dec 03, 2013 | Frigidaire Heating & Cooling
Flame is flickering
The Dometic refrigerators use an ammonia coolant which makes it different from residential units. A good steady flame is essential for proper operation. So first make sure that you are using a winter mix fuel, and that you tank is not close to empty. Obtain a long handled VERY SMALL wire brush (brass if you can find it), and then go into the back of the unit. First, gently clean the around the pilot light area especially the thermocoupler. Check the burner unit and see if you have a mostly blue or a lot of yellow flame. The yellow flame indicates impurities so you would would to clean that area of the burner.
Jan 31, 2012 | Dometic Refrigerators
I have replaced the coil pack on my 2002 ford taurus with the 3.0 24 valve engine. I have no spark to cyliders 3 and 4. I have also replaced the electical connector to the coil pack as well. All 4 wires...
All 4 wires have power and the yellow and white and the yellow and black pulse with the test light, the yellow and red and the solid red wire have a steady light with no pulse. The PCM - engine computer is no good , driver (transistor's) in side turn the coil on an off . Burnt transistors .
Mar 30, 2017 | 2002 Ford Taurus
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
Meaning of rudd furnace trouble codes
Error Codes
stuck open)
stuck closed)
increases
Dec 12, 2009 | Heating & Cooling
King kooker will not burn a blue flame, only a big yellow sooty
You may need to resize the orifice, sounds to me like it is too big. If you have an adjustable orifice try tightening it down a quarter turn at a time till that flame turn pretty. Leave that shutter wide open till you start getting a blue flame. Make sure you have no cob webs blocking the orifice.Blow out and remove all rust from the burner.
Mar 06, 2009 | King Kooker 1209
Intertherm P3RA-048K Air Conditioner Logo
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
