Question about Aiptek PenCam Trio II Digital Camera
I can't get it to take pictures. It shows the number 26 and starts off with Hr showing, but that's it. What's wrong?
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
My built in dishwasher ser no sm843049B-Model number GSD696ON1OSS will not reset. I mistakenly used the delay wash setting. It is set at 1 hr. I have used the start/reset button several times and the...
Try to do a hard reset by unpluging all the cords for 1hour and then plug it back.
Goodluck,
Please don't forget to rate the solution
Apr 11, 2008 | Dishwashers
Error code 212
212 Comms Error between Outdoor Unit and HR Box No3. 1. Defective connection in HR unit power supply and transmission connection 2. Wrong setting of the HR unit Rotary switch and Dip switch 3. Defective HR unit PCB
Feb 14, 2015 | Heating & Cooling
My Maytag washer is not spinning, it shows an error code hr... can anyone tell me what might be wrong with it? Help please
is this a top load or front load washer-top load has an actuator switch that goes bad part number W10006355-cheers Denny
Oct 26, 2013 | Maytag Washing Machines
Lg 26 inch tv flat screen, no picture but sound ok!
The inverter needs replacement. You should be able to get one from www.tvrepairworld.com
Nov 03, 2012 | LG Televison & Video
My 99 Pontiac Grand Am's radio is on Loc. I have the 2 codes but I don't know what to do now?
turn ignition switch ON but leave stereo OFF---press MN button and OOO should appear -----press HR button to make the last two numbers match your code then release button ---press hr button until the first one or two numbers match ur code ----press AM/FM SEC should appear indicating the radio is unlocked if LOC shows up either took longer than 15 seconds between entering codes or wrong code entered --u r allowed only 8 tries after that radio becomes INOP and dealer is only one able to reset
Jan 21, 2010 | 1999 Pontiac Grand Am GT
MY DESKTOP TIME IS IN 24 HR FORMAT
START->CONTROL PANEL->DATE,TIME,LANGUAGE.....->Change format of numbers,dates and time. Under regional and language option click customize option and select time tab under customize regional options . There would be an option to change date, time change format. Click that and it would fix the issue.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 02, 2009 | Computers & Internet
PROSCAN 26" LCD TV with DVD won't show all the channels
bought 26 in pro scan tv can't figure out how to connect dvd player,craziest thing i've ever seen.please help
Mar 14, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
42" LCD tv shows picture on only half of the screen,other half dark!
The T-Con board (otherwise known as LVDS) connects to two seperste parts of the LCD panel. If you do have half a picture (left or right) replacing the T-Con board should resolve this issue. Open your TV, find the part number and search on eBay or at sites like www.flattvparts.co.uk where you can search by TV model number.
Oct 27, 2008 | RCA L26WD26D 26 in. LCD TV
No picture, but sound
does it work if you connect dish??
Mar 30, 2008 | JVC LT-26WX84 26 in. LCD HDTV
Aiptek PenCam Trio II Digital Camera Logo
18 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
John Oughton
John Oughton
Level 1 Expert
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
