Question about Matsonic MS9307C+ (810884003185) Motherboard
I cant get the front usb port to work. The rear port works fine. I may have the plugs in wrong on the motherboard
  • 42 Answers
Try to find a motherboard map for the computer then make sure it is pluged in.
Posted on Sep 30, 2009
Failed usb headers
1) Power down or reboot your system.
2) As the pc is restarting, press the F2 button to pull up the "Setup" screen.
3) Right Arrow to the "Advance" tab
4) Make sure that all devices are enabled
5) Arrow down to "Miscellaneous Devices"
6) Make sure "External USB Ports" is also enabled
Feb 01, 2018 | Evga X58 SLI LE (25139) Motherboard
My usb ports stopped working. i unistalled them and restarted my computer. computer saw the usb ports on start up but still doesn't see any devices I plug into it. Is it a bad motherboard or a driver...
Some computers have both USB ports on the front and back of the case. The ones on the bark are directly off the motherboard while the ones on the front are usually connected by a separate cable. If you are trying the front ports, try one of the rear ones instead. if it works in the back, that cable may need to be reconnected inside the case.
Feb 26, 2010 | MSI 865GVM2-LS Motherboard
Front usb motherboard ports don't work rear ok. os/windows 7
You've probably connected the pins wrong. You should find the manual and see how your front USB ports must be connected
Feb 05, 2010 | MSI PM8M-V Motherboard
Usb ports on motherboard are not working. They do not seem to have any power. None of the ports work. Not even the front ones. I've tried reinstalling the drivers, installing different drivers, I've...
If the usb ports don't seam to have power, I suspect that at some time something was plugged into one of the ports, either at an angle or upside down, shorting the +5 vdc supply. Usually the supply voltage is fed to the ports thru a "zero ohm resistor", basically a fuse that blows protecting the power supply. You may be able to find and replace it but much easier is to install a 4 port usb pci card. They're cheap and you can go to 2.0.
Jan 13, 2010 | EliteGroup P4M800-M7 Motherboard
FRONT USB PORTS DOES NOT WORK
its typical that after a power surge, some capacitors or controllers are blown. It may seem fine, but maybe its only one circuit blown on the usb controller, which you cant see without a magnifier.
If you don't want to change the whole motherboard, just buy and additional USB PCI card
Skywolf
Mar 14, 2009 | Verbatim 96148 Mouse
USB DEvice not recognized
I had a problem like this -- tried plugging the camera in to the rear USB slots not the front ones and it worked fine.
I think that it doesn't like going via a USB hub, but wants a direct connection. All of the USB ports on my computer are connected direct to the motherboard (i.e. none are on PCI cards or anything), but looking at the hardware info for the computer, it looks like the motherboard has a few "direct" USB connections, and then an on-board hub which the front ports connect to. If your computers are the same, that would explain things. I'd suggest trying each USB port one at a time (turn the camera off before plugging in, and back on when in) and see if one of them works. Wouldn't hurt to power the camera from the mains at the time too.
Jan 01, 2009 | Video Cameras
The 4 USB Ports in the rear stopped working. Can they easily be replaced?
hi there,
the rear USB port cannot be replaced, & glad that you still have a front USB connections into your MOBO..?
May i ask why did they suggest you to use the front USB panel..? Can you give us some info why this was happen..?
Thank you
May 27, 2008 | PC Chips M957G Motherboard
Front Side USN dows not work in ASUS M2N MX SE
The front side port may be a "low power" USB port, it may be possible to "power" this if there is the capacity to connect a power cable to the front panel USB adapter, or there may be an aux power socket to plug into on the motherboard.
Nov 04, 2007 | ASUS M2N-MX Motherboard
Matsonic MS9307C+ (810884003185) Motherboard Logo
80 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
