Most commercial ovens have a manually lit pilot. There will be a button somewhere on the range that you will need to push in so gas will come out of the pilot assembly. While holding this button you will the light the pilot and will need to hold the button in for about a minute or two until the pilot stays on after you release the button. Look around the bottom panel,top panel or side panels(you may need to remove one) to find the button. they are usually red and may not look like a button. If you find the button and the pilot does not stay lit then the thermocouple might be bad. If you push the button and do not get any gas coming out of the pilot then there might be debris in the pilot assembly causing the gas not to come out. In that case you could try and tap the assembly or blow with compressed air to clear it. But in most cases you will need to remove the pilot assembly and use a really fine wire(like a metal tie-strap minus the coating) to clear the pilot orfice.
