Question about Sharp AR-207 Copier
My copier flashes the L6 code and 10 when I hit print, how do I fix this?
    President:
  • Sharp Master
  • 990 Answers
Hello sir; The error code you display, that's means laser motor problem, need to replace it the item# is DUNTK0041RS52.
Posted on Oct 01, 2009
Service l6 10
Sharp AR-M207 . Enter these keys one after the other to reset:
  1. # - * - C - *(pound, star, C, star).
  2. The screen will go blank and ask you to enter a code
  3. Enter "14" and press the print button.
  4. It comes back and asks if you are sure(showing "1" as default). Press enter.
  5. Machine should then reset
Aug 21, 2013 | Sharp AR-275 Copier
What does this code mean L6-10
change laser unit . or polygun motor.just do this
Apr 28, 2010 | Sharp AR-M450N Copier
Have got Call for Service Code:L6-10 up on
Hi there
I have copyed this from a website form.
AR-M450U laser code L6-10
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Customer called this AM with this code and I understand no kind of reset so I just ordered the laser unit from Sharp this afternoon. Should I have tried something else first. I didn't want to waste time if there was a high probability the laser or one of it's components would need to be changed. Frank /ActionPhotocopy
And This
You are spot on Frank. 99.9% of the time, it has a failure in the Polygon Motor assembly in the LSU. Very common on high page count machines. This part will fix the issue straight away. You will hear the new laser speed up nicely on startup compared to the original, which usually sounds abit sluggish or slow.
All the best Pineworks
Mar 18, 2010 | Sharp AR-M450U All-In-One Laser Printer
ERROR L6
An L6-10 code is a polygon motor failure in the copier's laser unit. It's what flashes the image to the system drum. If it won't clear after shutting down/unplugging the unit for 30+ seconds then the laser unit (the LSU) needs to be replaced. You'll need to contact a trained Sharp service representative to facilitate the repair.
Oct 01, 2009 | Sharp AR-M205 Copier
L6-10
According our service manual 'L6" sub code 10 is laser drive, motor, problem, replace laser unit . the laser unit item# is DUNTK0013QSZZ, it located at left hand side of the toner cartridge inside the machine. or it may be mostly due to Polygon mirror motor not up to speed... You may be able to air it out and fix the problem.
Jun 19, 2009 | Sharp AR-M450N Copier
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
Error code l6-10
Hope this helps.
Apr 24, 2009 | Office Equipment & Supplies
I have a sharp ar-m160
if you press the print switch while the l6 code is in the window you will get a second code. more than likly it will be a 10 that means your laser unit is bad & needs to be replaced.
Nov 12, 2008 | Office Equipment & Supplies
Error code L6-10
sir, I ma indian & I have a tosiba estudio 161 I have problem diaplay in on display screen when i switch on the start so display show screen ---
Jul 02, 2008 | Toshiba e-Studio 161 Copier Copier
My sharp ar-207 is flashing an L6
This is a polygon motor lock error (LSU).....This is a very good job if you never did it. You may wan't to service it or at least get a estimate...
Good lock !
Apr 04, 2008 | Sharp AR-207 Copier
Sharp AR-207 Copier Logo
245 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
