Question about Garden
Gas in the crankcase - Garden
  • 472 Answers
THE NEDEL IN THE CARB IS STUCK LET GAS RUN IN AND FILLS UP AND GOES IN TO CRANK CASE
Posted on Sep 30, 2009
Testimonial: "That helps thanks ,wayne"
Gas going into crankcase
Hi, Hb there are three ways in which gas can get into your oil tank/system:
1. Someone deliberately pours gas into your oil tank.
2. The vacuum petcock control rubber fails, which allows gas to flow from the fuel tank through the petcock, through the vacuum line into the intake manifold, then into the combustion chamber, where it seeps past the piston rings and into the bottom end where it gets pumped back into the oil tank.
3. Nonvacuum petcocks that are not turned to the off position will patiently wait until the float needle and seat no longer function properly thus inviting gas to enter the combustion chamber eventually finding it's way to the oil tank.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.kawasakimotorcycle.org/forum/kawasaki-streetbikes-sportbikes/130968-gas-crankcase-oil.html
Gas leaking into crankcase
Gas fuel in crankcase
Nov 12, 2016 | Motorcycles
What causes gas in crankcase
Gas in your crankcase is typically a sign of carburetor floats not set correctly. They allow too much fuel into the bowl which then overflows and goes into the cylinder and leak down past the piston rings and into your crankcase.
Jul 27, 2016 | Motorcycles
Why is there gas in crankcase
Hello Ricky, I would check the carburetor needle valve and seat along with the carburetor float. You could get lucky and just need to clean the crud out of the carburetor float bowl.
Nov 04, 2015 | Honda Es 6500 Gas Generator Electric Start...
Gas in crankcase
This sounds like it is an older vehicle with a cam driven fuel pump mounted to the block. If so the fuel pump is bad and leaking fuel into the crankcase.
Feb 17, 2014 | Vehicle Parts & Accessories
Blows white smoke
Check the Oil level. If gas got past the needle valve ( which happens more and more with this Ethanol gas ruining Rubber carburetor parts) Then gas will run down the cylinder walls and into the crankcase. Gas will mix with the oil and overfill the crankcase that will cause the mower to smoke like crazy.
Aug 09, 2013 | Garden
Have 307 86 gas in oil some pinging not really knocking or ticking. possibly diaphragm on gas pump allowing this through crank case or what should i do
there are only so many ways for gas to get into the oil.one someone purposely pured gas into the crankcase.two the engine is running very rich and not able to burn the excess gas,three the fuel pump is leaking gas into the crankcase,four the oil has not been changed regularly and the gas has thinned out to the point that it cannot seal the engine from the gas that normally is burned in the combustion chamber.If maintenance is regularly performed that fixes #4,I doubt that anyone would pour gas into the crankcase especially at the price of gas that fixes #1,if the carburetor is working as it was designed to then that eliminates running rich and fixes #2.if the above is good then the only thing left the fuel pump, can leak fuel into the crankcase and they won`t make noise necessarily.as far as the slight pinging one of two things can cause this, the engine is running slightly lean and or the timing is too advanced and needs to be reset to specs
Mar 02, 2011 | 1986 Oldsmobile Cutlass Supreme
I have briggs and stratton powered mower with the 18.5 v-twin ohv intek engine modle 407777 type 0121-E5 CODE 000512ZYG MY PROBLEM IS THAT MY CRANKCASE IS FULL OFA GAS OIL MIXTURE THE OIL FILTER ALSO...
When the float in the carb sticks, it allows fuel to drain into the cylinder, that runs pass the rings into the crankcase. When the crankcase is full the pistons cannot go down, and the starter won't turn the engine. Drain all the oil gas mixture, and refill with proper oil. Replace float, needle and seat in the carb bowl. Throughly clean fuel passages, and bowl. If motor won't turn, remove spark plug and turn over engine a few times to remove gas oil mixture from the cylinder too.
Oct 02, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
How come the gas mixes with the oil then when u drive it it shuts off
it seems to be a fuel related problem. the gas should not be going into the crankcase. It is leaking into the crankcase . The fuel system is somehow leaking into the crankcase because of excessive flooding, or other fuel related problem like a gasket . don't drive the car like that.
Feb 02, 2009 | 1993 Nissan Altima
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
