Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Corroded lip Just want to know how to remove the top section of washer so as to remove corrosion and repaint.
    Scholar:
  • 196 Answers
Need to know what you are referring to as the top. Do you mean the lid or the chassis top.
The actual top section is bolted from the inside.
Posted on Jan 02, 2008
The washing machine is rusted under the lid. How do I take the top off so that I can repaint? The model is RAX7245KQO. I need to take the top of the cabinet off to repaint. I need directions as to how to...
you have to use ether a screwdriver of a wedge in the seal about a inch below the top and pry up it is held by strong spring clips it will take some work when done you just pop it down unplug unit first hope this helps
Aug 30, 2010 | Roper RAX7244KQ Top Load Washer
Washer not agitating or spinning, when the washer was tipped to access gearcase there was a pin on the ground.. I know it came from thr washer, but where?
check the lid switch if it is out /or the metal bracket .is off the washer will not operate ..you need to pop the top section of the washer to get to the switch ..their are metal clips that hold it down in the front ..so get a flash light to find them they are about 3 inches from the sides in the seam of the top section of washer...let me know ..good luck/joe/
Aug 27, 2010 | Kenmore Washing Machines
Winshield Fluid Container Leaks and repair shop said that the acid from the battery has corroded the container and this is a continual problem with the Yukon based on the fact that the container is located...
If you have the money try using a newer sealed battery. These new sealed batteries do not require fluid top ups and can not leak unless over charged (generally leading to them popping...). You do not want battery fluid leaking through your engine bay. At the extreme you will have to life out the engine and sand down then repaint the engine bay to stop corrosion and rust.
On to your leaking fluid container - I am not familiar with your model, however many of these containers are removable with just two screws, once removed they can be replaced with a cheap second hand one, or patched with a plastic filler. My choice would be the second hand replacement.
Dec 28, 2009 | 2005 GMC Yukon
Need to repaint bubbled and peeling paint on top of dryer
The choice is yours. Money often motivates these decisions. If the model number you have this listed under is correct, the top panel price is roughly $108 to $160 depending on the color you need. White or Bisquit is the cheapest, while Pewter is the most expensive. If you wish to replace it, appliancepartspros.com carries it for the cheapest price.
If you wish to paint it, remove the panel from the dryer first by locating and removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. This will allow you to work on it in a more convenient location and avoid any overspray from paint on your appliance. Make sure you clean the surface throughly to remove anything that may have caused the paint to bubble and peel in the first place (Ospho is commonly used to clean metal surfaces in preparation for painting - clean AFTER you sand). I would sand with a fine grit sand paper or emery cloth to ensure you don't leave any surface scratches. Prime the entire panel to provide a good surface for the new paint to adhere to. Once the primer is dry, apply a couple of good coats of appliance paint. If you have questions, please let me know. I hope this helps you.
Sep 06, 2009 | Whirlpool GEW9250 Electric Dryer
How do you remove top of new washer so dryer will sit on top?
There should be 2 screws at the rear of the top section. Remove those screws and pull the top backward and it should come off.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
1998 F 150 regular cab paint peeling problems
Ford will not assist on a 1998 vehicle because of the age.
You can primer and spot paint but it would probably do better if you sanded it down first.
Mar 04, 2009 | 1998 Ford F150 Regular Cab
Problems with LG WM-2277HW Front Load Washer
It is a rare problem but I've seen it happen.  The only way to resolve this issue immediately is to remove the top of the washer to gain access to the dispenser.  The dispenser can be disassembled by unsnapping the top section where the hoses are connected.  Once the top section is lifted, you can safely pull the drawer out.  Not sure what happened but more than likely the water dispenser has warped downward causing it to jam the drawer.  Recommend replacing the dispenser to resolve this problem.
Jul 23, 2008 | LG WM-2277HW Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
