Question about Garden
My Karcher 205 M is leaking water from the bottom of the casing during normal operation. I have bled the system and the water flows through fine until you turn on the motor, then it starts to leak, can you help, I have rung Karcher and been told it sounds like the pressurised motor system faulty and a new motor is £50.- Many thanks, Glynn
HVACRH20
  • 237 Answers
SOURCE: Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
Posted on Jan 08, 2007
SOURCE: karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Posted on Jul 16, 2008
SOURCE: Water leaks during rinse cycle
My Washing machine is leaking in gearbox.the quality of water is bad (Hard)
Posted on Aug 07, 2008
  • 98 Answers
SOURCE: Amana washer model LW6501W2 leaks in front during fill up
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: Water leaking from underneath water tank.
I rang Saeco service centre about my leaking water tank and they posted me a new tank - no questions or need to return the faulty item. I believe there may be a bad batch of tanks which leak because of faulty valves.
Posted on May 10, 2009
I have 2007 BMW 335I that has been sitting in my garage for a month and started very little. the last time I started it the low coolant level light came on. Itis not leaking anywhere. What type of coolant...
Hi Robert, No it is not normal for the coolant level to drop at any time. The BMW has a system which must be bled to free it of all air. The bleed screw is situated on the radiator and has a screw driver slot. Open the bleed screw and replace the coolant with the recommended coolant and then finish topping up with water until all bubbles have cleared from the system. Observe the level and if it drops again have a pressure test carried out on the system as if the level drops again, there must be a leakage. Likely places are hoses, and the water pump. If it is the water pump, the leakage may only be evident during engine operation, unless the leakage is severe in which case you will notice coolant dripping. Regards John
Sep 15, 2012 | 2007 BMW 335i Sedan
My Karcher KB 9030 has lost pressure and is hunting when no demand water supply is plenty
In most cases the water lines can have leaks that bring bring in air and so the pressure will be less. Power off the washer and let the water flow without any air bubbles. If you seen bubbles then recheck the joints.Check the same with the outlet.
If not there is fault on the main pressure pump.
May 02, 2011 | Karcher Garden
Karcher k1 leaking from inside casing.
The most likely issue, which seems to occur alot with karcher, is a cracked water pump. What happens is that as you release the trigger on the handle, the rise in pressure should cut off the motor, but as it also cuts off the water flow at the wand end and the motor spins a few more revs until it stops, then there is a huge pressure glitch which blows apart the weak plastic pumps that they use. Since the plastic cracks it is very difficult to repair and the only option is to go and buy another. BUT...this time tape up the trigger on the handle so it is always on and then it won't blow itself up. Just use the unit on/off switch to turn the motor on and off.
Apr 11, 2010 | Karcher Garden
I have a karcher 495, it is puslating when it is
It sounds like there may be a pressure leak somewhere in the system. The machine cuts off when there is no flow of water past it. If it is leaking then there is intermittent flow. Which would make the machine run then stop continuously.
Nov 15, 2009 | Karcher K 5.85 M Electric Pressure Washer
I have a Karcher pressure washer that leaks from the pump when operating.
could be little plastic pressure hose outlet,they can be porous and let pin holes of water through,pull plastic casing apart and remove high pressure hose outlet (black 'L' shaped pipe gun pressure hose outlet,ive repaired a couple,and machine works fine after
Oct 18, 2009 | Garden
1994 Honda Civic LX\overheating within 2 mile drive
Remove and raise upper hose at thermostat end and remove lower rad hose.
Fill rad with a hose and watch for flow from bottom rad hose and/ or bottom rad hose connecton.......water should fall though rad easily.
Honda rads are cheap.....any restriction....replace rad.
Remove thermostat....fill thermostat housing with hose and watch for water flow at bottom rad hose.
Flush good.
Remove heater hoses.......flush back and forth until a good flow is present "With heater control set to hot" if no or poor flow....replace heater core.
Stop leak can plug everything.
Also.......not likely causing over heating....but ....at your mileage,if you do not know if the timing belt has been changed.....CHANGE IT NOW!
Water pump is optional at this mileage.
Aug 23, 2009 | 1998 Honda Civic
Heater matrix has gone on my 405 diesel bypassed it
sounds like your inner cooler is leaking and is causing an air lock within your coolant system. Sorry to hear this, changing this part is time consuming. Hope this helps you.
Jul 26, 2009 | 1991 Peugeot 405
Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
772 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
