Question about Pride Mobility Victory 3 Wheel Electric Scooter
How do you slow the unit down? - Pride Mobility Victory 3 Wheel Electric Scooter
  • Pride Master
  • 1,271 Answers
Use the speed pot on the from control panel, if it still too fast take off the control panel,
look for the three throttle wires, pick the left hand , now get a 5k pot from maplins or rs depending on your location, wire the central locator and the left or right side locator as a straight connection so one wire from the left let and one wire to the central leg now take a wire off the throttle and connect to one piece of wire and the other to the other end of the wire, hope that makes sense, now you increase the resistance from the pot and now when turn fully on for boths pots will slow down the scooter
Regads
GeWiz.
Posted on Oct 01, 2009
Just installed Archtic King 5,000 btu window AC unit. It has no thermostat and runs all night long. Every few minutes the AC slows down like a brown out and the lights dim. Why would it brown out?
If the compressor is having a hard time starting it will "pull down" on the electricity causing it to sound slow. Your compressor is probably not starting and this will make it run all the time with no cooling. The air will feel cool but not cold. If it is a new unit take it back. If it is a used unit it may have a loose or disconnected wire, a weak capacitor, or damaged compressor/circuit board.
Jun 10, 2015 | Heating & Cooling
My microwave oven siows down and then speeds up.
Is it still heating food properly? You can perform a basic test with a microwave safe mug or plastic cup of water. It should be boiling or too hot to touch within 1 to 2 minutes. Be careful not to overheat the cup if plastic and use extreme caution when touching or removing it from the microwave.
If it is not heating properly then the magnetron may be faulty and unit should be replaced.
Can you tell what specifically is speeding and slowing? Is it the turntable or the humming sound of the unit itself? Many microwaves vary their intensity in order to heat/cook evenly and that will vary the pitch of the sound you hear and sound like it is speeding up or slowing down. If the turntable is slowing and speeding up then there may be a bad motor and the unit should probably be replaced.
If the unit is heating adequately and the turntable speed is uniform then what you may be hearing is simple power cycling and/or fan noise.
Only trained and certified technicians should attempt repair of microwaves due to the hazards of high voltage and microwave radiation leakage if parts are not replaced properly. Although you can have a microwave repaired the cost may be equal to, or higher than, the cost of an equivalent new unit for a 900w microwave.
Feb 28, 2015 | West Bend 0.9-cu. Ft. 900-watt Microwave -...
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
Unit slows down ,bogs down
check the belts , if there not lose then the incoming power could be low or the motor could be going bad.
Apr 19, 2010 | Ingersoll Rand - Rand Type - 30...
A/C starts up/Cools/Fan Slows, Unit Shuts down in 4 minutes
Ensure proper voltage to the unit. Check for overheated/damaged wires and/or connections in the control panel as well as at the fan motor and compressor.
Apr 03, 2010 | Dometic Rooftop RV Air Conditioner
Boxlight CD-725C TEMP light comes on and unit shuts down afer 10 minutes. Unit has about 1200 hours on the bulb. Seconds before the unit stops, at least one of the fans slows down.
The reason why the temp comes on because the fan is start slow down, so the bulb produce a lot of heat. Once the maximum temp reach, the temperature sensor will become inactive. So boxlight shutdown. First you need to replace the fan, or check the supply dc voltage going to fan if it is stable.
Jul 24, 2009 | Office Equipment & Supplies
Problem in scanned images uploading
If you have 50 units of computer working the same time such as uploading big files, the problem for the rest among your 7 computers that work fast is between the hub connectors on the network system. You can check this connectors by replacing those slow ones to that faster computers.
Then if your faster computers slow down and the replaced connectors from slow working bacomes fast then the problem is in your hub distribution connectors.
If you had trace to that problem, then replace the whole unit of hub connectors.
Aug 08, 2008 | Microsoft Windows XP Professional With...
Speakers making vibration noise and slowing computer down
I see you've been waiting for an answer. This one is weird--try calling their support:
General Product Phone Support (United States) +1 646-454-3200
Monday - Friday: 6am - 6pm PST
Saturday - Sunday: 7am - 5pm PST
Mar 11, 2008 | Logitech X-530 Computer Speakers
Optoma projector
would need a model number to get this nailed down but it sound like you have a DLP projector, this might have a color wheel in it, sometimes when this fails you get flash of colors as the color wheel slows down then the unit sences that the color wheel has stoped and shuts down the unit
Mar 07, 2008 | Optoma Multimedia Projector
Pride Mobility Victory 3 Wheel Electric Scooter Logo
145 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
