I found the following steps on another website:
Press yellow clear key, enter 107, press and hold down the orange clear/stop key for 5-10 seconds, switch off main power for 7 seconds and turn back on.
I did not however, see (and therefore do) what you mention of the setting the SP1902 001 to 0. Will this "hurt" our copier? Do I still need to place the maintenance call? Thanks!
Press the total reset(yellow) key - 1 -0 - 7 and press and hold down he stop ((red) key for more 3 sec.Enter in the SP mode(activate to press on the touch pane) open the front door turn OFF the power main switch,unplugged the machine amd wait 10 sec.Plugged the machine,closed the front door and turn ON the power switch.The copier is worked.If neccessary to check and measurement the continuity of the fusing unit parts:heater lamps,thermofuses,thermoswitch and if cleaning used the izopropilalkohol.
His solution should reset the code if it does not you need to test the lamp, thermistor and fuse
This worked perfectly for a Ricoh 3245C. Thank you!!
