Question about Canon DR 3080C Path-Through Scanner
I have a canon dr-3080c that will scan all but the last page have to put blank sheet of paper to complete scan job, have replaced roller kit for other problem and the kit repaired that problem but still will not scan last page hopper goes back down when it get to last page.
  • 490 Answers
I think this is rubber roller problem. Obviously, the scanner cannot find out which is the last page. If the paper available is less, the roller is not pulling the last few sheets.
S. Mohan
Posted on Oct 01, 2009
The DR-9080c scanner will take a whole stack of papers (20 or so) and shove it thru the paper path, not just the top sheet. On old laser printers there was a paper pick that got slippery. Is there one in...
Ensure that the "BYPASS" button on the control panel is not illuminated. Make sure the "Standard Feeding " is selected in the driver. Try cleaning the lower separation roller. Make sure the separation roller is pressing up against the feed rollers. If the roller set is worn, order a replacement set of rollers (Google: Canon 9080 Exchange roller kit)
Apr 04, 2012 | Canon DR-9080C Path-Through Scanner
Why is my Canon DR-3080C not feeding paper thru
Hey!
If you lift up the cover you will see 2 sets of roller,try cleaning them with a damp cloth and one at the bottom too,if that fails you can replace them and it is not expensive!
Hope it helps!
Jan 12, 2011 | Canon DR 3080C Path-Through Scanner
I have a DR-3080C II, which I've replaced one set of rollers on to fix paperjamming issues. The scanner occassionally picks up two pages at once, scans the top one, spits both out like it was one. I'd...
What Scanning software are you using? If CapturePerfect, there is an option to detect double page. Once you select this, the scanner will STOP, if two pages are sucked in and the panel will display "d04" indicating double page. Also Wipe all the rollers with a well wrung damp cloth for every 2000 pages to remove paper dirt.
S. Mohan, Chennai, India
Dec 16, 2010 | Canon Office Equipment & Supplies
When scanning, there are lines on the image I have scanned.
Use a blank sheet of paper (as white and clean as possible). Put it in the scanner landscape ( you will need to cut off about 1/2 inch of the paper to make it fit. The run the DR-3080CII Shading tool (DR3KUserSh.exe) C:\Program Files (x86)\Canon Electronics\DR-3080CII\DR3KUserSh.exe
May 19, 2010 | Canon DR 3080C Path-Through Scanner
Getting vertical lines on scanned pages when duplex scanning on canon dr-3080c II scanner Only on duplex side of pages, though. Front page still shows up clean.
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
Jul 10, 2009 | Canon DR 3080C Path-Through Scanner
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Scanner pulls page in to just past the bottom sensor lever
Please ensure that the rollers are clean and within its life span. (Rollers wear out and need to changed after 250,000 pages or as recommended by mfr). FAn the pages before scanning, Ensure the edge is trim with no folds or bends. The griniding noise is because the scanner has picked up more than one page.
S. Mohan. India
May 29, 2009 | Canon DR 3080C Path-Through Scanner
Dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
Apr 16, 2009 | Canon DR-5010C Scanner
Scanner can't scan multiple papers by itself.
Ensure the rollers are clean. Clean with with a damp cloth or with IsoPropyl Alcohol (IPA Industrial Grade). Dont use solvents. Check if the papers are sticky. Sometimes stapled documets are held together at the point where is it was stapled. The small 'depression' is enough to hold two papers together.
Jan 14, 2009 | Canon DR 3080C Path-Through Scanner
Canon Dr3080c
I need to find a service manual that will help me replace the roller kiton our Canon DR-3080C
Oct 07, 2008 | Canon DR 3080C Path-Through Scanner
Canon DR 3080C Path-Through Scanner Logo
107 people viewed this question
old marine
old marine
