Question about Dell Dimension 2400 PC Desktop
How do you open the tower of a dimension 2400 tower
  • 855 Answers
If you look at the CPU from the back. On one side usually the left you will see a screw where the side wraps around the back. Some brands will use two screws. Remove this screw and then you can slide the side panel back toward yourself. Then you can turn the CPU exposing the open side. While your in there (make sure the unit is not plugged in) take a can of compressed air and clean your cooling fans and vents. Keeping a computer cool is important to keeping good performance up to where it should be.
Posted on Sep 30, 2009
Dell dimension 2400 keyboard and mouse and monitor not working
i think its a hardware issue so you should contact to dell care..
May 05, 2012 | Dell Dimension 2400 PC Desktop
How to remove computer cover
Try this website..this is a manual for Dell Dimension 2400 PC Desktop
it includes how to remove the cover of your tower. Check it out..
http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf
Sep 14, 2010 | Dell Dimension 2400 PC Desktop
I NEED HELP IN REPAIRING THE FRONT HEADPHONE JACK ON THE TOWER, AND WOULD LIKE TO HAVE ACCESS TO THE SHOP REPAIR MANUAL. DELL DIMENSION 2400 DESK TOP PC, THANK YOU AND KINDLY APPRECIATED !!!
You can just remove and replace the front I/o panel rather than repairing it . The part is not more than 10$. You can get the part from the following site
http://www.txcesssurplus.com/servlet/the-5850/Dell-Dimension-2400-4600/Detail
or
http://www.impactcomputers.com/d0971.html
How to remove the front panel
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/fpanel.htm
Thanks for using fixya
Proton
Aug 20, 2010 | Dell Dimension 2400 PC Desktop
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
May 28, 2010 | Dell Dimension 2400 PC Desktop
My dell dimension 2400 goes on standby automatically.
If the power LED on the Tower is blinking amber, then most likely the power supply in the tower is failing. Replace the power supply.
Dec 31, 2009 | Dell Dimension 2400 PC Desktop
Removing sides on a Dell Dimension 2400 tower
Lay the case on its side and depress the "buttons", there are is one on either end. The case opens like a **** shell, if you start to open it and it feels very heavy on the top, stop and turn it over so the motherboard is toward the floor, that will make it easier on you.
Sep 08, 2009 | Dell Dimension 8300 PC Desktop
HOW IS THE WIRING SET UP IN MY DELL DEMENSION 2400 DESK TOP// I AM TRYING TO PUT BACK TOGETHER THE IINSIDE OF THE TOWER NOT SURE HOW IT IS SUPPOSE TO LOOK
Most of the connections only fit in one place ...
Here is the Service Manaul for the 2400 Dimension.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/index.htm
Jun 13, 2009 | Dell Dimension 2400 PC Desktop
Can a Dell Dimension 2400 take a GeForce 6600 graphics card?
This card can only Be installed in a Tower CPU. Your Card slot will not Accept this.
Jan 23, 2009 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
212 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
