Question about Mitsubishi WS-55807 TV
Won't turn on
So my 55807 won't turn on so i took the back piece off to see if I could find anything wrong with it. Anytime I go to plug it in all i do is here a click from inside the tv but nothing happens. Suggestions? Anything that I can do for like process of elimination?
I have the same problem with a ws55807. I started checking power to the unit with a voltmeter. For those intersted I have attached scematics: I verified that the PCB main fuse is good and there is 120V at point PT. From what I can tell is happening, the power button is pressed and the P-ON transistor is given a signal to conduct which causes K9A50 to close. K9A50 opens after about 3 seconds.
I am looking for other troubleshootinng steps. I have checked fuses F9A01 and F9A06, both are good. What are some other things to check for? Where does the P-ON signal come from.
In the switched supplies regulator circuitry I found fuses F9A04 and F9A05 blown. I jumpered around F9A04 and F9A05 with good 5A fuses and the TV powered on. However when the set was plugged into an outlet the was a huge power draw.
The TV stayed powered on for about 30 sec and then powered down.
I pulled the middle PCB whichs holds these circuits and I found the
D9A60 diode open and IC8C02, one of the convergence IC's fried. I don't know if these were like this before or after jumpering.
I replaced all bad components and I am back to square one. The K9A50 relay stays closed for 3 sec and the set does not power on any further.
  • TV_ITGuy Dec 20, 2007
    I replaced both of the convergence IC's. I bought 2 Sanyo IC's from Audio Labs of Georgia STK392-570's for $ 20 each.
    Thanks I will check the items mentioned.
    Also, do yu know the circuit logic behind the K9A50 relay opeing and closing. Is there a way to determine what the control unit is not seeing that tells it to shut down the P-ON signal?
    Genius:
  • 1,694 Answers
The five amp fuses are very fast acting pico fuses, by design.
You say you replaced both convergence IC's or not?
Let me know....T.
PS What quality,price and part # IC's.....?
Posted on Dec 19, 2007
  • Vista Electronics Dec 20, 2007
    You chose well ! Now you are probably going to isolate.......
    How about checking each active component in power supply...
    then check electrolytic caps....You no doubt already checked
    all the other fuses...Then check every component that the B+
    and minus voltage sources that drew hard current touches...any
    peaking coils,resistors,etc .....one part open will shut you down................................................T.
    Re-check your own soldering of IC's and re-check IC's pin for pin
    comparison for shorts.............................................................
Mitsubishi WS-55807 Error Code 24 Vertical Deflection Failure. 5.
Hi. The service manual is in more than one part.
Schematics are in part 2 here:
Download Service Manuals for free
Jul 30, 2016 | Mitsubishi WS-55807 TV
Rav 4 temp/oil light, engine light, battery light one above battery light won't go off clunking noise no power now it's not going what's wrong
start with the checkk engine light , scan the car and give me the code number , some thing els make sure that your battery is good
Mar 26, 2013 | Cars & Trucks
Jbl speakers turn off on their own
Sounds like you have them plugged into the wrong jack
Jan 01, 2013 | JBL Jembe Two-piece Entertainment Speakers
Took washer apart, put it back together and now it won't start
ok... seems that it is trying to fill but wont...first...for all problems after dis-assembly of anything...I always recheck all wire connections...yould be amazed how a wire can be pulled off and you not notice it...next...if they are all tight...next ensure your water supply is turned back on at the faucet....try unplugging the unit from the wall, waiting 5-6 mins and plug it back in..to see if the controls reset..phillip
Jul 04, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Apr 08, 2012 | ASUS Eee PC 1000HE Netbook
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Won't turn on
Check for voltage at the end of your power cord. If you find voltage there next check for voltage on the other side of your glass type fuse.This will most likely be your problem.
good luck-------------------------tomtaso
Nov 30, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
