Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
The fridge part becomes warm every 6 months. I have to empty the hole fridge, unplugged it and let it thaw with doors open for 72 hours...
    Scholar:
  • 103 Answers
Check that defrost heater is working. Pull back wall of freezer out, unplug refrig, unplug defrost heater and check with ohm meter that heater is good. If heater is good then check thermistors are good, if reading correctly, then change mother board.
Posted on Oct 01, 2009
How do i fix a loud noise coming from my frigidaire glrs264za refrigirator?
Sounds like you have ice buildup next to the evaporator fan that circulates air inside the fridge. Ice buildup happens due to too much moisture - door open for extended periods, leaky door seal, heating system meant to de-ice the fridge not doing its job. You can approach this two ways. Unplug and leave both sides of the fridge open for at least 24 hours to let it thaw, or open up the fan cover and thaw it with a hair dryer (fridge unplugged ofcourse). Option two is faster, but more labor intensive. This wont solve the underlying problem of ice buildup, but will get rid of the noise for some time (likely months).
Sep 06, 2014 | Refrigerators
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Fridge door was left opened and now the fridge wont work but freezer working fine
All the cold air comes from the freezer side so if the fridge side is not cooling then the baffle door is not opening up or it has accumilated ice in it and frozen up. I would try to unplug it for a hour or so with the doors open and let it thaw and then plug back up and let it run for a couple hours to see if that fixes it. If not then I would suggest having the baffle checked.
Apr 29, 2011 | Maytag MSD2656G Side by Side Refrigerator
The fridge and freezer smell like a dead animal. cleaned the inside with bleach but still smells for weeks. model w10212088
There are two reasons for bad smells. 1. Long time not being used. 2. Lack of cleaning inside compartment.
Solution: Unplug fridge. Keep open fridge door. Dip a dry cloth in soap water and start cleaning each and every compartment. Keep freezer door also open. And then clean with another dry cloth. Keep both doors open for nearly 5 hrs. It will be enable fresh air to **** the smell inside fridge.
After 5 hrs close the fridge and run on empty for one hour. Keep food items after one hour. Please keep all food items closed vessel. Not only it's avoid odor but also be hygienic.
If you use to keep fish items in freezer, clean fridge once in a week.(Spray roo spray in the room when you keep fridge door opened. Don't spray into fridge.)Helpful.
Jan 30, 2011 | Whirlpool Refrigerators
The freezer is fine but the lower fridge is at 58 f
There is ice build up blocking air flow to the refridgerator compartment. Put everything in a cooler, turn fridgfe off, thaw OVERNIGHT with BOTH DOORS PROPED OPEN and then rinse freezer with a liter(big slam) of water. Let sit 5 minutes and pull bottom drain pan . Empty it. IF YOU RUSH THIS THEN The internal ventalation will still be blocked. 12 hour thaw minimum even with doors open.
Jan 27, 2011 | Kenmore 63712 Top Freezer Refrigerator
I have a hotpoint fridge with water on the door. Even with the temp turned to its warmest setting the water like freezes up. I unplug the unit and open the frezzer door wait 30-45 min and it clears up. If...
Very common problem. Usually it is caused by a bad insulation of the door. Try turning it off for 72 hours. That way not only the insulation of the door will thaw, it will also dry out. It should last longer, when it's not wet. The easiest solution is to replace the door, but it's not reasonable pricewise.
Hotpoint refrigerator repair orange county, ca
Feb 06, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Freezer thawed, fridge warmed
The compressor is short cycling, or not starting. being purchaced in 2004, the compressor may be under a 5 year part and labor warranty with SEARS ...BUT GOOD LUCK!!!. Find ur receipt and warranty. read carefully and hold them to it.. empty it and unplug to be safe
Aug 25, 2009 | Kenmore Refrigerators
Fridge storage
Definitely unplug it and leave the door open a couple inches for air to circulate. otherwise, when u need it again it will be contaminated with mildew.
Apr 20, 2009 | Whirlpool ED5VHGXM Side by Side...
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
81 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
