Question about D-Link DIR-625 (790069292637) Wireless Router
I have a dir-625 router and only 1 computer gets the internet. There are 2 other computers in the home, which can not access their internet. How do I fix this?
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . possible is the setup of your router is not correct, here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 03, 2009
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
My router suddenly stopped working yesterday and I've tried everything I can think of to fix it. I have one computer wired directly in to it and a few laptops that use wireless connections. The...
Please try to access the router's configuration page by accessing 192.168.0.1 using a computer that is wired on the router.
Default admin user name:Admin
Default admin password:
Please update firmware:
Note:Please do not upgrade the firmware over wireless connection. Anyway you wont be able to do that now but for future reference. Please use the link on the bottom.
DIR-625:
http://www.dlink.com/products/?tab=3&pid=DIR-625&rev=DIR-625
DIR-625 rev C:
http://www.dlink.com/products/?tab=3&pid=DIR-625&rev=DIR-625_revC
Jul 10, 2011 | D-Link DIR-625 (790069292637) Wireless...
I don't know how to set a password on my d-link router because my internet is insecure. How do i do this? I have the default username and password, but i don't know what to do from there.
1.Open your Internet browser and type in the default IP address for your DIR-625 wireless router: 192.168.0.1. A window will appear asking for your DIR-625 wireless router network name and password. If you do not know your existing network name, enter the default network name, "Admin." Leave the password blank. If you have already set up a network name and password, enter it now. Select "Log In."
2.Select "Wireless Settings" from the left-hand navigation bar. Put a check mark in the box marked "Enable Wireless."
3.Type your new wireless network name for your DIR-625 in the box labeled "Wireless Network Name."
4.Type your new password for your DIR-635 in the box labeled "Pre-Shared Key."
5.Select "Save Settings" from the top of the screen to save your new password.
Feb 07, 2011 | D-Link DIR-625 (790069292637) Wireless...
How can i lock my d link dir 625 router?
Access its built-in web-server (as per the instructions in the manual that came with the hardware) and:
1. change the "admin" password
2. add "MAC-address-filtering", to severely limit the MAC-address(es) of the computer(s) that you wish to allow to connect.
Sep 13, 2009 | D-Link DIR-625 (790069292637) Wireless...
What is the router address for dir-625
Actually dir-625 have default IP Address: 192.168.0.1
Default admin username: Admin
Default admin password: (blank)
Also check it in your Local area connection, your Gateway Address: 192.168.x.x
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | D-Link DIR-625 (790069292637) Wireless...
No connection to DIR-625
Make sure the modem is connect to your router under the WAN
Access the configuration page of your router. using the address bar.
type in 192.168.0.1
Username : admin and leave password blank
Under WAN choose dynamic and click on clone mac address.
Click on Apply then click on continue.
Go to Status if you have IP address it means you can connect to the Internet.
Mar 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have installed 2 delink routers for my Mac, I still cannot get on line. the mac is new, what is the problem?
Try to configure the DIR-625 wireless router. Connect your computer to one of the LAN port to one of the router. Then access the IP address of the router (192.168.0.1) configure as dynamic IP then clone the MAC address. Make sure that you modem is connected to Internet port section of the router. Check the Internet connection after the configuration leave the other behind check the connection of the main router before installing the other one.
Mar 10, 2009 | D-Link DIR-625 (790069292637) Wireless...
DLink DIR 625 Wireless Router
It is the wireless computer setup with the same network name?
Feb 08, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cannot access the internet through my DIR-625
Check your IP address to 192.168.10.1 on the network settings
after that turn modem and VoIP off.
Click on Setup / Manual Internet
Select Dynamic IP under "My internet connection is"
Click on "Clone Your PC's Mac address"
Click on Save settings, if it ask for reboot click on reboot
After the router reboots (NOT COMPUTER), it will take you back to the router.
Once your are in the router, turn the modem on first then the VoIP.
After the modem and VoIP has finish rebootin
Click on the status tab of the router and check uder the "WAN"
Settings and check the IP address. If you get an IP address then check the internet.
If you do not get an IP address Click on Release and then renew.
If you still do not get an IP address click on Advance tab
Click on Advance network on the left and turn UPNP off and save the settings.
After that it should be able to get an IP address and you should be able to get online.
Nov 05, 2007 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
