Question about Necchi Sewing Machines
Necchi 586(Silvia) Stiches problem
Necchi 586(Silvia) I am having a problem in stiches,they are not going on proper order,sometimes they miss the next interval & runs to the next.what can i do about this??
RickE1
  • 202 Answers
SOURCE: My machine stiches automatically when turned on! Help
It could be because there is a wire pinched in the covers to look for or a bad L-print circuit board BUT... Because the foot pedal is not jammed does not mean it isn't working correctly. Inside the foot pedal are two big springs that lift up what is called a carbon pin housing (that has a hook that attaches to the top of the footcontrol)that has carbon contacts attached to it. When these are lifted up the machine is stopped. When you press the footcontrol down it presses the contacts down and speeds up the machine. So somehow this carbon pin housing hook has become disengaged from the footcontrol and the contacts are sitting at the bottom allowing your machine to start at full speed. If your not afraid to fix this yourself heres what you do... 1. With a small screwdriver go through the tiny hole on the bottom of the foot control and adjust the potentiometer. (the potentiometer will only turn 3/4 of a revolution.) 2. Hold the foot control while removing the 4 screws and the two bridges. 3. Carefully release the housing (spring pressure) but do not pull the housing apart. 4. The top and bottom cover are connected by a hook. (if its not broken off) I think this is your problem since most likely the hook has become unattached. At this point though it would be good for you to clean the strips that the 2 carbon pins slide on with a q-tip and remove old carbon residue. Check to make sure the 2 little black carbon pins are not broken. (if they were the machine would not run at all). Be careful not to hurt the carbon pins) 5. To put this back togeather properly... insert the carbon pin housing into the bottom housing of the foot control (if you took it completely out). 6. Insert the two springs 7. Insert the top cover and hold it down while installing the 2 bridges with the 4 screws. to connect the hook follow the rest of the procedure... 8. Press the bottom and top togeather until 2 loud "clacks" can be heard. The clacks indicate that the hook engaged into the latch. 9. Now operate the footcontrol several times by hand up and down. It must be possible to hear clearly the soft clicking of the micro switch. If the clicking of the micro switch cannot be heard repeat step 1. Good luck. Your only next step will be to bring it to a tech or get a new footcontrol. (spendy) Rick.
Posted on Aug 27, 2007
  • 323 Answers
SOURCE: L-344 loose stiching
You need to do a tension assembly test. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Posted on Dec 24, 2008
  • 323 Answers
SOURCE: My JAnome sewing machine is 24 years old and has
Your machine has a timing problem and should be seen by a technician to repair it.It is possible that there is a loose part also.
sewman7
Posted on Apr 30, 2009
SOURCE: I have a quantum cxl.
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Posted on Jul 02, 2009
  • 288 Answers
SOURCE: I have a Necchi Silvia Maximatic 586. I haven't
oil it
Posted on Dec 18, 2009
I am trying to find a replacement 'pattern selector' part for a Necchi Silvia Maximatic 586. Do you provide them or know where I can get one?
Parts are not provided here. Only advice and suggestions.
You might try searching the internet for your machine model plus the word "parts" Might also contact a local sewing repair shop who may be able to order what you need.
Nov 12, 2015 | Necchi Sewing Machines
English manual for necchi silvia multimatic 586
for a manual check with sewingpartsonline.com
sewusa.com
Mar 20, 2012 | Sewing Machines
Please let me know where I can buy a bobbin winder for NECCHI SILVIA maximatic 586. Mrs.N.Perera.
Your machine is not actually made by Necchi, it is a standard model that lots of manufacturers buy and have their own name put on, email me and tell me what the problem is kendourof@yahoo.com
Aug 08, 2011 | Necchi 3537 Mechanical Sewing Machine
I need the proper instructions on how to adjust the timing on my 7422 singer advance sewing machine. I used the buttonhole ...and ever since the machine is missing stiches and half of the other stiches...
You can try a whole new needle, inserted with the flat side facing away from you. Sometimes a burr or slight bend causes you to miss stitches. I would not attempt to set the timing myself as you may cause some damage. You can also call Singer customer service at 1-1800-4singer and they can advise you. Be very cautious of advice on the internet.
Sep 11, 2010 | Singer 7422
My bottom stich is loose. which know do I use to
I found my book & was able to solve my problem with my irregular stiches with the proper adjustments.
Thanks anyways.
Oct 27, 2009 | Necchi 3102 Mechanical Sewing Machine
Sewing Machines Logo
64 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
