Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I tried to start my older Poulan Chain saw a day after I had been using it. I find it almost impossible to pull the starter cord...there is too much resistance. If I take out the plug and pull the cord everything works fine. When I put the plug back in and aloow the compression to be there the problem in pulling the cord occurs. Any ideas of what I can check...I can't find a service centre in my area.
    President:
  • 2,220 Answers
Did you remember to mix oil with the fuel before you put in the tank?
Remove the spark plug wire and the spark plug. Remove the muffler. Shine a light through the spark plug hole and inspect the cylinder through the hole where the muffler was. Is it smooth and shiny? Use the starter to move the piston up and down slowly. Is it smooth or does it appear scratched and gouged?
I suspect parts of your piston are adhered to the cylinder wall. If that is true it will probably cost more to repair it than to replace it.
You needn't take it to a poulan repair center. Most Stihl outlets employ good mechanics and can repair any saw. HTH
Lou
Shh... my Husqvarna gets serviced by a Stihl dealer... The Husqvarna dealer is actually closer to me. I feel better about the Stihl mechs.
Posted on Sep 30, 2009
Testimonial: "Very helpful"
How much compression should the saw have?
What Causes Too Much Compression on Poulan Chain ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Many makes of gasoline-powered yard tools, including Poulan chain saws, use two-cycle, or two-stroke, combustion engines. ... Pull the rope out and oil it to see if that helps the problem. ... How Much Compression Should a Stihl 066 Have? ... Pull Starter on a Poulan Chain Saw · Oil Pump Removal on a Poulan Chain Saw ...
The Timber Trades Journal and Saw-mill Advertiser
Nov 26, 2015 | GCSP Husqvarna 340 345 346 350 353...
#pp5020av pull cord
The length of the Starter pull cord is 40"
It can be purchased at www.ereplacement parts.com
I have no affiliation with this site or company. They simply have great prices and also list exploded views of this saw and others.
http://www.ereplacementparts.com/poulan-pp5020av-stroke-gas-chainsaw-parts-c-16962_17147_162366.html
Aug 04, 2014 | Poulan Pro Pp5020av Gas Chain Saw 20" 50cc...
Poulan 18" PP4218 Pro 952051338 It has fuel
you may need to clean your sparkplug, or replace it
Aug 05, 2011 | Poulan 952051338 18Inch Chain Saw Chain 38
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan 14" chain saw has become difficult to
If you have more questions or need additional help pleasereply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa. gif,gif89a%12%00%12%00%b3%00%00%ff%ff%ff%f7%f7%ef%cc%cc%cc%bd%be%bd%99%99%99zyzrur%00%00%00%fe%01%02%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%21%f9%04%04%14%00%ff%00%2c%00%00%00%00%12%00%12%00%00%04x0%c8i%2b%1d8%eb%3d%e4%00%60%28%8a%85%17%0ag*%8c%40%19%7c%00j%08%c4%b1%92%26z%c76%fe%02%07%c2%89v%f0%7dz%c3b%c8u%14%82v5%23o%a7%13%19l%bcy-%25%7d%a6l%df%d0%f5%c7%02%85%5b%d82%90%cbt%87%d8i7%88y%a8%db%efx%8b%de%12%01%00%3b
Jan 09, 2011 | Poulan 14" Chainsaw
Recoil starter
If the end of the cord won't hold a knot to keep it in the reel, try melting the very end of the cord with a match to form a small lump. If the cord is too short so that you are coming out to the end before getting a good run-up in the starter, replace the cord with a longer piece (obtainable from any servicing dealer). Buy the same diameter of cord. Hope this helps!
Apr 20, 2010 | Poulan ES350 16" Chain Saw
Poulan Pro 18 inch saw. Once the unit is warm it
start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
Sep 23, 2009 | Poulan Pro Chain Saw 46cc 20"
Hi i have a Poulan chain saw and it will not
well there are generalloy two issues with any motor. SPARK and FUEL
Remove the plug and hold it near the entry point of the plug hole so it earths to case. Pull starter cord and see if the plug has a stong spark.
the should also be some wetness on the plu indicating fuel is pumping. Place finger over the plu hole and pull cord avoiding any spark but check the amount of pressure in cylinder. The pressure should be stronmg enough to push your finger off the hole
Replace plug and open the air intake and spray some AEROSTART into air intake pull start cord. If this does not cause it to attempt a start, I would suspect the coil is fused and will need replacing
Aug 11, 2009 | Garden
The cord to my Poulin chainsaw is sticking
To traxtor06
Your problem sounds like a broken starter spring. If the spring is broken it will slip allowing the tension to be released and not fully retract the rope.
Mar 27, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Pull start on my wild thing keeps jamming
you can not pull the starter rope out to full length. Just short rapid jerks. everyone has this problem
Jan 26, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
221 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
