Question about HP Photosmart C5280 InkJet Printer
Printer is connected and ink is full but printer is printing blank sheets of paper
    President:
  • 787 Answers
May be the cartridges are clogged.Try to replace them.
Posted on Sep 30, 2009
I have ink in my printer but when i hit print it wont print anything out, just a blank sheet of paper
If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the cartridges are clogged with ink, so no ink can go down to the paper and that's why you see a blank sheet of paper. The other option is that you think you have ink in the cartridges but in fact it was finished.
I suggest you to replace the cartridges.
Hope this helps
Alex
Sep 12, 2011 | Lexmark X2670 All-In-One Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Printer prints blank pages
The print head is a part of the printer itself and unlike other printers, you cannot remove it or soak it without ruining your printer. So just try the print head cleaning option and perhaps replace cartridges, especially if you are using a third party or refilled cartridge which can clog even if it is full.
Mar 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Dec 27, 2009 | Canon Office Equipment & Supplies
When i print the ink is so light it looks like a blank sheet
get some paper towels and boil some water put in in an old coffee cup. hold the ink cartridges over the water (not in) the steam will clean out the nozzles on the cartridges. the ink will run a lil bit (hence the paper towels) give the printing a go again.
hope this helps..
Nov 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Printer spits out blank page before printing
Check Your Ink Catridge. If the Catridge ink is full then try the following Steps.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Mar 02, 2009 | Brother Multi-Function Center MFC-240C...
My printer will only print blank sheets
Hi!
You'll need to call kodak and ask for a new printhead.
Their number is 1.800.421.6699.
This is a very common problem.
Please rate my solution as FIXYA!
Thank You!
Feb 09, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Canon Pixma MP 610 Pixma Printer
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP Photosmart C5280 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
