Question about Apple (6612068) Sound Card
IBook sound card performance?
I'm using a G4 iBook for my home stereo - it goes direct to block amps and thence to the speakers. Would I get better audio if I used an external soundcard instead? I'm looking at the Emu 0202 USB 2.0, which claims to have 24 bit I/O, 32 bit processing, and full 24 bit resolution at all sample rates. Is that better than the iBook's soundcard?
  • markvc1 Dec 19, 2007
    I should add that what I'm playing is Apple Lossless files.
    Ok, back up a step.... is it POSSIBLE to use an external soundcard instead of the iBook's internal one?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 52 Answers
I've seen USB soundcards, on ebay, that you can plug in and use...they were pretty cheap tho, so dunno if you'd want one...but I guess that it shows that it is possible to do :>
Posted on Mar 19, 2008
How do I reconnect to the internet, I restored my iBook G4 to factory settings and although I am connected via Airport am receiving an error message that no ports are open . Everytime I try to open T
The pointer jumping on the screen sounds like you may have picked up a virus. While rare, there are mac viruses. I would try to save all my data documents and any other valuable personal files or lists, then do a clean reinstall of the operating system. Then load our documents back in.
You could try to scan for a virus with a mac virus program, but not many are available for a G4 Power PC (PPC) machine.
May 10, 2014 | Apple iBook G4 Mac Notebook
When i try to boot my ibook G4, a grey screen comes up and then it states "you need to restart your......" in different languages, I tried to reboot in safe mode: by pressing down the "shift" key and...
that's a kernel panic, which means there's probably a problem with your operating system. Use the original disks to reinstall the OS.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
Jul 30, 2013 | Apple iBook G4 Mac Notebook
No sound from speakers
You don't mention the sound card(s) in the PC nor the method of connecting to the monitor. Some video cards have HDMI connections for audio and video out to a monitor and will not allow any other audio outputs to work. Regardless of sound source interface, check to be sure that the audio source is the one that is NOT part of your video card and is NOT set to output DIGITAL audio signals.
Once this is done, select the the "add-on" or "expansion slot" sound card (if it is the type that plus into a slot on your motherboard) or the "built-in to the motherboard" type (if the jacks are soldered directly to the motherboard) as the DEFAULT or ENABLED. Set to ANALOG output - NOT digital if a choice is offered. Connect the speakers. This should be via cable terminated with a stereo mini jack - NOT a special digital optical or coaxial cable / connector. Most modern PCs will have several mini-stereo jacks from which to choose - nearly all use the GREEN ringed jack for the FRONT (or main) left & right stereo speakers. Regardless, if yours has GREEN jack, you should use it - if none have a color code, look for markings that indicate either "speakers" ,"output", "front" or "L & R". If there are no indications, check your manual. Set your volume level on the lower side, play an audio source and adjust speaker volume and / or audio mixer settings in the system tray as needed.
Only one sound card will work in a PC. Make sure that all connections are made to the ENABLED card, otherwise no sounds will be heard. Digital output is primarily targeted to facilitate connections to external amplifier and speaker system - most often like those found in a Home Theater PC setting - or a monitor / TV connected by an HDMI cable.
I hope this helps & good luck!
Jun 04, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I have 3 sets of 2 ceiling speakers install throught the home for listening to music from ipod, cd, fm, etc... These speakers are not for home theater use (I have another 7.1 system for that). My question...
firstly you could be experiencing "phasing" as you may have not spaced/set up the speakers properly. Also make sure plus on the amp goes to plus on the speak and ten - to - on the amp and speaker. cross them over at any stage or pair and again you will get your problem.ugest
It could also be you sre over driving your amp. How many ohms is each speaker and how many ohms is your amp capable of? 6 speakers to one stereo amp with one speaker out is very rare and usually quite damaging to equipment.
personally I would suggest one pre amp (to plug sources into) then 3 stereo power amps (one for each pair of speakers)
Jan 16, 2011 | Audio Players & Recorders
My G4 iBook screen goes dark shortly after I power-up, even If I hit the F2 key, the screen remains dark.
Got the same problem with my ibook G4.
I have research on how to fix it, and found out that most model of G4 has the same problem.
I soon found out the main problem and the solution, it would require some skill in soldering and dis assembling the whole laptop.
Go to this site and hope it will help you just it like it helps me a lot!
http://macintoshhowto.com/hardware/how-do-i-get-my-broken-g4-ibook-fixed.html
Thanks for using Fixya!
Dec 14, 2010 | Apple iBook G4 Mac Notebook
Philips tv with sound going in and out
Try bypassing the set's speaker by running an external audio amp. I use my bookcase stereo for audio direct from the satellite receiver and turn the volume off on the TV. Sounds better this way! Could be the audio amp in the TV is going bad or the speaker may be bad and the TV's audio amp goes through a shut down cycle.
Feb 10, 2010 | Philips 30PW850H 30" TV
Ibook g4 speakers dont work
Ibook g4 have speakers in the Top Case assy. You need new top case assy.
Oct 05, 2009 | Apple iBook G4 1 GHz 12" w/ Combo Drive ...
Can i connect my bose 5.1 speaker system to my pc directly without using a separate stereo receiver? my pc has a 5.1 hifi with optical sound card and an 800w psu.
no it can not. the sound card in your computer has no power behind it, only a signal. the acoustimass needs power from an amp. you can connect your computer to a home theater reciever and get what you are trying to do, with a simple 3.5 to rca cable.
Jul 15, 2009 | Bose Acoustimass 6 III System
I would like to know if I can use my Polk speakers on a Compaq 510 Evo c.p.u.
please check its compatibility in the user manual, if its going to work on your present OS or platform. then if its plug and play. And better check if the Audio input/output plug is compatible with your soundcard outlet at the back of your computer if so, please try to insert then have it tested if this will make sound...
Aug 04, 2008 | Polk Audio Computers & Internet
Memory upgrade for ibook g4
Hi-
you can check a lot of sites where you can view and check onthe step by step guides how to install or upgrade the memory of your ibook, check this links
http://www.memorystock.com/memory/AppleiBookG412GHzM9419LLAMemory.html
http://www.edgetechcorp.com/memory/apple-ibook-g4-memory.asp
http://www.powerbookmedic.com/Take-Apart-Repair-Manuals-p-1-c-258.html
just select the type of memory card that you are using and it will lead you to a page where you can download a pdf file of the instruction.
Hope this helps, pls rate as fixya if it helps. thanks!!
Jun 26, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple (6612068) Sound Card Logo
138 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
