Question about Acer Aspire 6930-6941 Notebook
I cannot play a DVD or DVD ROM in my drive. The hardware is not faulty, maybe the drivers?
  • jigglethattw Oct 01, 2009
    It's a software DVD, Sims 3 to be exact.
  • Sarasvatas Kumar
    Sarasvatas Kumar May 11, 2010
    what kind of dvd's are you playing????? is it software dvd or dvd movie
2 Suggested Answers
  • 13433 Answers
SOURCE: DVD/CD Rom Drive
Hi
your solution is here
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Posted on Jan 08, 2009
Cd drive not working
try another cd like a music cd or if its a dvd rom try a dvd. could be a bad disc also try rebooting the computer
Dec 28, 2011 | Computers & Internet
Dvd drive will open but not play anything
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they could be faulty ?
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jun 07, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
Hello, My problem is that the drive does not eject smoothly. It has to be given a gentle push to close and has to be pulled to open. What is the solution for this problem? The drive burns and play disc...
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 23, 2010 | ASUS (GENEIRC DRW-1608P BLACK)...
No d3d drivers found with hardware
when i run IGI game they give me an error (no D3D drivers with hardware acceleration is not found
Aug 25, 2009 | Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD...
IGI play
no d3d drivers with hardware acceleration found
Jul 22, 2009 | Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD...
Dvd does not work. Light blinks but not seeing it . is there a driver i need or what do i do to fix this
You must determine if the problem is the media you are using (CD, DVD) or the drive itself. (CD/DVD Rom)
First see if the driver is installed for the CD/DVD ROM by Right clicking My Computer and choosing Properties, Hardware, Device Manager. Clikc the plus sign next to DVD/CD Rom Drives to see if there is a yellow exclamation point, or question mark. This means you need to install the correct driver. If there are no yellow exclamation marks or question marks your driver is installed properly.
Next try playing difffernt CD's to see if any of them work. Confirm they are good CD's by playing them on another device, then try them on your Compaq. If the Cd's play on another device you may possibly be experiencing read errors on the CD/DVD Rom drive. Try using a CD Laser Cleaner that will clean the laser head of the CD /DVD Rom. it looks like a CD with small brushes on the music side. This may solve a read error problem. if that does not solve your problem you may need to replace the CD/DVD Rom drive.
Jun 14, 2009 | Compaq Presario Notebook
Cd rom problem
Try to play different cds from your dvd rom drive.
If all of them does play then i suspected the cd that you had inserted to play is faulty.
If all of the cds doesn't work, re-install your dvd rom driver. If it doesn't still read any cds then your dvd rom drive is faulty.
Note: If machine is under warranty no need to pay for the repairs.
Jun 04, 2009 | Dell Inspiron E1505 Notebook
After I reinstalled my pc, the toshiba dvd-rom (sd-c2502) only plays cds, not dvds.
Try re-installing your the driver for your dvd rom. Then try to put different dvds and check if it can read from your drive. If problem remains, I suspected it's your dvd rom is faulty
Jun 02, 2009 | Dell Computers & Internet
Acer Aspire 6930-6941 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
