Question about Irons
I have a Tobi steamer, The steam is not coming out like it should how to I unclog the hose? I do know its the hose. Thank you
My wife has thrashed hers in her shop and it suddenly stopped steaming. It was about two years old. I managed to fix it. I dont think that the hose or the nozzel will be blocked because they are too wide a diameter. There will probably be a build up of silica or calicum inside. Unscrew the hose where it meets the machine. Remove the blue water tank. If you pour some water down the pipe from the end that you just unscrewed the hose , the water should well up in the depression where the tank sits through the little holes at the bottom. If it doesnt then the blockage is inside which is what I found. I used some decalcification liquid product ICL and poured it in from the hose end and let it soak for 10 minutes. Then I got a thin plastic tube to go in and scrape around as far as you can from the hose end. A thin bottle brush or pipe cleaner would be good. I then used a thin piece of wire to poke around the slits in the other end( depression) Then I emptied it out and continually flushed it through with water and give it a good shake holding your hand over the hose end connection hole. I found that when I emptied the water out , it contained all this silica and residue. I would have got about a teaspoon full in total. After several goes the blockage suddenly cleared itself and I found that suddenly the water was running through freely and welling up as described. I kept doing this until the gritty residue dissipated. You can hold the hose end under the tap and tilt the machine so that the water runs freely out through the depression well. I reassembled it and tried it out. Bingo just like new. Hope this helps. - Grant
Posted on Sep 15, 2010
  • Purpleknite Jan 01, 2011
    I tried the CLR. It worked. I'm back in business. Thx.
Pour vinegar in the section where the hose is connected. I did that and shook it out a few minutes later. There is alot of lime in there. Once I did that the steamer was working like new again.
Posted on Aug 26, 2010
I'm having the same problem with mine, I'm going to try pouring white vinegar in the water tank it usually breaks down lime scale - I think that's what the problem is.
Posted on Nov 19, 2009
Tobi Steamer Problems - no steam coming out???? Unscrew hose and pour down tablespoon of white vinegar leave for 10 minutes and pour our rubbish that has accumulated in the bottom of the steamer. Mine took about half bottle of vinegar to clear blocked section. It was full of ants and they had nested in the bottom of the steamer.... Mine is working perfectly now. May need to pour down a little warm water where you removed the nozzle being carefull not to wet the motor. Keep tipping the machine to emty out the bits of stuff that had blocked the machine.
Posted on Jun 03, 2012
It is the material of the heater thing. When you are done with steaming. Let it cool off and pour water in through the connector and pour out will will notice all kind of rocks and sands. No way water creats those stuff that fast
Posted on Jul 08, 2014
I added vinegar to the water container. I also stick a wire thru the hose....and let it run....the vapor started coming out again!
Posted on Mar 19, 2014
Hose
Either jammed up with limescale or the heating element is faulty. contact Conair to confirm
Feb 09, 2014 | Conair GS10RHR Deluxe Fabric Steamer
Euro-Pro X
Check the hose for something clogging it. It will be past the flattened area (by that I mean further from the steam cleaner). It sounds like something got stuck in the hose, and as the steam cleaner kept sucking on the hose, it caused the hose to flatten.
Sep 08, 2007 | Euro-Pro Steam Generator EP8001 Iron
Rowenta 1500 garmet steamer no longer makes steam
Someone else had this fix and it worked for me: (yay!)
*Remove water tank and collapse the hanger bar.
*Remove two screws at base of hose and work the hose off. It will come out.
*Unplug unit and hold over your kitchen sink with the hose inlet pointing into the sink.
* use your kitchen sink sprayer to forcefully spray water into this hole and it will come back out again releasing the gunk that has been stopping up the unit.
* for good measure, I also used the sink sprayer to flush out the hose.
Put everything back together. And make sure it is dry before you plug it in.
VOILA!!! WORKS GOOD AS NEW. HAPPINESS!
Jan 10, 2014 | Conair Gs4 Iron
My Tobi Steamer will not power on?
Check the fuse in the mains plug and replace it with a like value one. If this doesn't work your iron is at fault.
Jan 08, 2014 | Irons
My rowenta steamer has stopped steaming, it's a is6100, Ive had it for about 2 years.. I have rinsed out the bottom where the water tank connects with the bottom. I've noticed several black particules...
Having the same issue, if you have found a solution short of buying a new one, please share it...I am thinking surely there is a reset button but have not found it yet.
Jan 31, 2011 | Rowenta Commercial Garment Steamer - White
Hot hose but no Steam
Don't know this machine but if it has brass jets on the head stick a pin or a needle into them twisting while pushing in and out, some times these jet block up. other wise undo hose and blow through it hope I have helped in some way.
May 19, 2010 | Rowenta Commercial Garment Steamer - White
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
Would you return this PS200 steamer?
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
Jun 13, 2008 | Homedics PS-200 Iron with Auto Shut-off
Irons Logo
10,004 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
