Question about Olympus D-490 Zoom Digital Camera
Camera will not power on. Lens will not extend after cover opened. No LCD window visible.
SOURCE: Lens not Extending
this problem is caused because that the lens servo can`t move the unit of lens. this menssage mean that the sistem don't go out the lens. You have to sincronise the mechanism of the lens, carefully disarm the unit and review that the gears are ok.
Posted on Jan 27, 2007
  • 34 Answers
SOURCE: Casio EXILIM camera lens will not extend fully!!!
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
Posted on Jan 25, 2008
SOURCE: No power when the cover slides open
It is easy to remove the front cover. 2 small screws hold it on. Try cleaning the on/off switch underneath or it may need replacing if damaged.
Posted on Jun 01, 2008
SOURCE: Sand in camera
I have a camera and I dropped it in the sand. The zoom works and everything, but when I turn the camera on and off you can hear the sand inside the zoom. I am really worried because I am not preparhed to have it repaired as it is out of guarantee. I was wondering if there is a way to fix it.
Posted on Aug 21, 2008
SOURCE: lens cover stuck open
v12mike--you rock! this did indeed fix my stuck lens cover.  to add on to your solution, i had the top half of the cover stuck shut and the bottom half stuck open.  to get the bottom half to the shut position, i covered the lens with a little piece of paper and then used tweezers (VERY gently) to ease out the inner segment (segment 2 i think by your account), and held it in place as i reset segment 1.  this did the trick!
appreciate your help immensely....cheers!
Posted on Oct 11, 2008
Canon lens cover won't open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 09, 2009 | Canon PowerShot A630 Digital Camera
Lens cover opens only a **** on Sony DSC-W80
Please read carefully below procedure how to remove "Barrier Block" (what you call Lens Cover)..
Turn camera power ON so Lens will extend.
Take out battery so lens will remain extended.
First silver ring needs to be removed with help of tweezers as shown in below image..
Now you will see 2 screws at front of lens, unscrew to remove barrier block (lens cover) as shown in below image..
You need to have new barrier block with following part number..
A-1205-001-A BARRIER BLOCK ASSY
Subject part is available in Part Store
Install new barrier block as shown following image..
Insert battery and power up camera to check does barrier block works fine.
Need further info, let me know.
Good luck.
Feb 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Lense won't retract on Canon Powershot SD630
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. You're also more likely to be successful trying these than going inside the camera:
Finally, if you absolutely must open the camera, here's a couple guides to replacing the camera's LCD that may help:
http://cannonlcdrepair.blogspot.com/
http://digitalcamerarepair.googlepages.com/sd600
Jan 04, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Need to know where the ribbons plug into the canon sd600 lcd screen
What ribbon cables are you trying to install? Would this be the LCD+Backlight cables? Or the Lens+CCD cables?
As for the lens cover, http://stores.ebay.com/DarnToothySam has lens flap/cover repair, email him if you don't see your camera there.
Nov 09, 2007 | Canon PowerShot SD600 Digital Camera
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak DX6340 Lens Cover Does Not Open
Aug 13, 2006 | Kodak EasyShare DX6340 Zoom Digital Camera
Olympus D-490 Zoom Digital Camera Logo
50 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
