Question about LG enV Touch VX11000 Cell Phone
The internal screen has randomly stopped working. It displays nothing. The Speakers and internal keypad still function, but the screen does not.
I have the same problem its why im here :(((
Posted on Jan 28, 2010
Dont have a solution to this problem but the same thing happened to me on mine today...and the bad part is this is the only phone I decided not to take the insurance out for and now I am screwed.
Posted on Jan 06, 2010
Key board not working COPIER>FUNCTION>CLEAR>ERR.
Do you mean the LCD display is not responding , or that the number keys do not work, or both? I suspect that the keypad and display do work but your real issue is that you cannot enter service mode to reset an error code. Entering service mode can be a little tricky on that model. Hit *(Add. Functions, not the * on the keypad). So , to review, * then the 2 and 8 key simultaneously, then * again will get you into service mode. A screen will pop up that says Copier and other stuff. Select Copier. Then hit function tab at top of display. Then Select Clear (CLR) Then Error(ERR) then hit ok at the bottom of display. Then cycle power, if the error resets, you are done. If the error comes back, you need a part. Important----do not randomly clear any other items in service mode. You can cause a lot of problems if you do. Only clear that error code. Hope that helped. If not, you need to call a technician.
Sep 03, 2014 | Canon Ir 3300 Black & White Copier
I cannot turn it on
I actually am having the same problem with my old microwave. Mine also turns on when I open the door too (not sure if this happens for you though).
Anyway, to fix the problem of it not turning on (I wasn't seeing any numbers on my machines display, but the machine DID have power, so hopefully yours does too). All I did to fix mine was: I started pressing buttons on the keypad (my machine is digital and I assume your machine is also). Not just any keys though, press the function keys (usually toward the top of the keypad). It might be necessary to do this quite a bit. Also, don't just press one key over and over, try pressing random/different function keys with each press. It overrides the computer inside the microwave and in the process any issues which are keeping the programming from functioning properly (aka: numbers being displayed onto the screen). If and when the problem is fixed, you should be able to press your clear button and then it should function properly.
So to sum it up, the machine is probably getting power, but [probably because its old] the internal computer more than likely has issues (software and/or hardware issues) as can be expected with older machines like this. This is just a temporary fix though, you really need a new machine (at least that's my case). Its just old and needs replaced more than likely.
Dec 25, 2012 | Ovens
All buttons have stopped working
Hi, different possible places to check,
The flex,
keypad IC.
The flex of the phone.
The flex is connected to the screen and it makes the screen display,Also if the flex gets damaged it will make the key pad not to work.
The keypad IC is found inside the phone boardand it make the keypad the function.If IC gets damaged, might cause keypad noe to function.
It depend of the keypad your talking about, if it's the lower key pad or the upper keypad where the menu is.
If it's the upper keypad is damaged, that means the keypad area is faulty,and will need to be replaced.
Have a nice day.
Sep 03, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
Speaker Problem
Nothing is wrong. Most computers automatically turn off the internal seakers after the external seakers are connected. Go to cntrol pannel and see what you can do under audio options or some such equivelent. Check back with more problems,
hope this helped/helps.
Mar 10, 2008 | Audio Players & Recorders
Cell phone problem as below
the cable may need to be replaced or have the keyboard service.
Jan 24, 2008 | Motorola Mobility A630
Outer keypad of motorola A630 does not function properly.
take the phone and have the keyboard (Outer) replaced or service.
RAZR V3C Display Problem
you may have to get the flexcable or the lcd replaced take the mobile to a mobile service center or a mobile tech and have them check your mobile.
Aug 25, 2007 | Motorola Mobility RAZR V3
Buttons dont respond correctly
Sounds like one or more of the keypad buttons are sticking - That would also cause the remote control to stop functioning.When you saw "P:0 V:0" you somehow managed to put the tv into the service menu. Pull the keyboard away from the plastic buttons and make sure nothing is in the way.
Aug 22, 2007 | RCA P52929 52" Rear Projection Television
LG enV Touch VX11000 Cell Phone Logo
621 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
