Question about HP Pavilion dv9000z Notebook
Light blinking when power button is presed but laptop not coming
The laptop first began cutting off during use. On powering up the last time I got a notification to update java security. while I was installing update, the laptop rebbooted with a black screen and a single line with files being counted down as if something was being scanned or erased. I powered down the notebook and tried rebooting. The notebook never cpowerd back up. The light will come on and the notebook will shut down immediately
    Guru:
  • 1,049 Answers
There is no software that can make the computer fail before the BIOS posts. Very little that won't at least allow the kernel to boot. So you can always at least get to the BIOS which loads from a chip, not from your drive.
If you can't, it's definitely a hardware issue and you should begin standard hardware troubleshooting on the board. If you can, boot to a utility CD/DVD and test the drive. The computer uses virtual memory which constantly shifts portions of the operating system between the hard drive and RAM. This means a heat related failure can also corrupt the data on your drive, cause restarts during RAM intensive processes like an install, and cause funny behavior.
Heat related damage is the most common problem in laptops because they run fairly hot and people like to use them on beds and couches which are soft and therefore block the vents. When laptops don't ventilate properly the memory, video, and hard drives will be the first to fail.
Be prepared to have to reload your OS and all your software if this is the case. Recovery can be very hard.
Posted on Sep 30, 2009
  • 40 Answers
Hard drive error or software error
run the diagnostics test under the bios... f2 at the beginning..
if the drive checks good
then boot and hold down f8.... to get to safe mode
get back with me about and answers
My Acer 6800 on button light comes on, wont shut off! Wont boot up all the sudden!
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 02, 2012 | Acer Veriton 6800 PC Desktop
Toshiba satellite will not turn on
LOL at your comment to take it to Best Buy to the Geeks.
May 01, 2012 | Computers & Internet
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
Mar 31, 2012 | Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Mar 30, 2012 | Computers & Internet
What's wrong with my will not com on with power bottonlaptop
Mar 29, 2012 | Computers & Internet
When i turn on, the green light comes on then goes out,why
Mar 28, 2012 | Computers & Internet
Battery light dosent work during charging or fully charged. Light comes up at times. battery level is either not indicated properly
In most models the battery light is displayed when it is charging with a possible blinking when it nears charging and it cuts off when the charge is full.
So if your laptop shows that the battery is charging in the task bar- bottom right, then you can ignore the issue unless your laptop is in warranty and it can be done free of cost.
If you open power options in the control panel the charging will be displayed , if this show Ok then the fault is the hardware circuit issue on the mother board power section.
Jan 22, 2011 | Computers & Internet
My canon ip90 does not print, continue to get 5100 error msg
you can try this method to reset the error..
First close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.), then while holding the Power button, release the Resume/Cancel button but do not release the Power button.
While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange. During initialization, the LED blinks in green. When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. Pls note each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.
Then press the Power button, the LED lights in green, and the
selected function is performed. When the operation completes, the printer returns to the menu selection mode automatically. Last just power off then back on and test.
May 28, 2010 | Canon PIXMA iP90 InkJet Printer
I was watching tv and it suddenly cut off; soon thereafter the red light near the power button began blinking and I cannot turn the tv back on
Power supply board is dead.Replaced the power supply board will get ur power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Feb 15, 2010 | Panasonic Viera TH-50PX80U Plasma TV
My Whirlpool Dishwasher cleaning light stays on
Try unplugging the machine from power to reset the program, if that fails you may need the control panel replaced.
Apr 19, 2017 | Whirlpool Dishwashers
HP Pavilion dv9000z Notebook Logo
868 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
