I need to retune my set top box but my remte will not work
  • 215 Answers
Please check user guide here
http://www.quick2view.co.uk/
hope this link helps you
thanks
Posted on Oct 01, 2009
I need help setting up a 5 way remte control to a Magnavox sdtv converter box
If the remote is universal, you can do a code search to find something that works. If searching doesn't work you may have to try a different remote. Some of the newer remotes such as Philips, RCA, and GE have specific SDTV codes.
Sep 11, 2016 | Magnavox Televison & Video
My new olin set top box will not pick channel tcn 9
Just try to retune all the channels it should pick it up. Everyone had to retune because 9 changed their frequency
Nov 29, 2013 | Computers & Internet
Retuning ViewSonic N2060W
This set only supports Analog transmission. Digital transmission is not supported.
You need a seperate Set Top Box to solve your problem.
Nov 20, 2012 | ViewSonic N2060w 20 in. LCD Television
I need to unlock my Platinum Telefunken set top box. My remote won't work at all and I put new batteries in and it's not that. The green light is on "Lock" on the actual set top box....
I have the same problem, but with no picture at all on my HD Channels. All I did was to retune my TVs analogue channels and bingo I got all my HD Channels back. My HD Set Top Box is still showing as locked.
Aug 08, 2011 | Televison & Video
Picture and sound break up on ITV3.
You'll need to tell us what TV, set top box you have for us to help. In the meantime, check your aerial connections to make sure they are secure and try a retune after that. Often, doing a retune without the aerial connected, then a full retune with it connected does the trick; this 'flushes' old channel settings in some equipment. In my area, ITV3 is a bit iffy and I cured my problem by checking all my coax connections up to and including booster and aerial.
May 03, 2010 | Televison & Video
We have a bush set top box with no instruction book. one channell Win (9)is indicating ''no reception'' We were told by a local TV repairer to re tune our tv. How?
Hi
You should not have to re-tune your tv as the set top box will be plugged in via a scart lead so its the set top box that needs to be retuned.
Go to the menu of the set box and select new installation under features or set up.
Hope this helps
Apr 09, 2010 | Televison & Video
How to connect settop box to tv with no avs
You will have 2 UHF plugs on your set top box.. One for input (aerial) and 1 for output (TV). Connect your main aerial to set top box UHF input and connect an Output UHF lead from set top box to TV. Next switch on set top box and retune tv on a spare channel until you get set top box channels (good idea to switch on menu on set top box so you know you are tuned into set top signal )
Feb 12, 2010 | Philips Televison & Video
The humax keeps on messaging that the antane cable is short circuited. is this an internal problem or a problem with the aerial itsefl
The Humax PVR-150T will definitely have problems using an indoor set top aerial; this is true of almost all Freeview receivers. Freeview signals are typically hundreds of times weaker than terrestrial transmissions and if you've managed with a set top aerial so far it's been working more by luck than design. I find that most set top aerials are so badly made that they're often faulty when new, but as most tend to flogged cheaply at markets and car boot sales the supply chain has no incentive to improve the product.
There has recently been a national Freeview retune, to complete this correctly your box needs the kind of solid and reliable signal which you cannot get with a set top aerial. Some receivers had compatibility issues with the retune and in many cases manufacturers broadcast OAD's (Over Air Downloads) to update the firmware in the boxes to be compatible. OAD's almost never successfully install via set top aerials.
There is an official list of Freeview devices which are known to have problems with the retune; unfortunately it has not proven to be a comprehensive list. The Humax MG-TU1 is one of those which have had problems and from memory it's closely related to your Humax PVR. The official advice is that you contact Humax directly on 0870 247 8800, but they'll probably instruct you to test your box using the aerial system it's designed to use before they'll be interested in offering further assistance.
Nov 05, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
Problem retuning Sagem PVR6240T set top box
Hey Agoodwin,
Looks like you have missed the final software updates for the PVR72xx and 62xx series last year. The bad news is that Sagem are not likely to send another update for their old models. If you check your box settings and you have software version 0.4.5. or less, your box will probably not work again. Sorry, mate...
Oct 05, 2009 | Televison & Video
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
