Question about Stanley Factory Reconditioned Bostitch U/RN46 1 1 3/4" Coil Roofing Nailer
Air leaking near trigger
I bought this Nailer (Ridge Runner) from a used shop few days ago, I tried to use Yesterday, after few shots the Air started leaking near trigger.
Thanks
  • 2,176 Answers
The purple O ring is split I would take it back or if you want to try and fix yourself let me know and I will help
Posted on Oct 02, 2009
How do u get the trigger assembly out of a bostitch ridge runner? Do u knock the pins out that hold the trigger in place and if so do you have to replace them with new ones?
there are detailed instructions on my profile page under tips. and unless you damage the old ones no you don't have to replace them. Let me know if you need more assistance.
Mar 10, 2011 | Stanley Factory Reconditioned Bostitch...
I have air leaking out the nose of my nailer. When I removed the nose the upper chamber holds air pressure. After I put the nose back on it will hold air pressure, but after I shoot a nail it will start...
sounds like the packing is shot. you need to oil it 2 times a day if its a constant use tool, drain your compressor everyday if its below temps do it twice a day. before removing the packing try putting lots of oil 10 drops into the nailer it might just be **** caught in it but **** can ruin the packing.
Dec 13, 2010 | Porter Cable PorterCable Coil350 312"...
Blowing air through trigger area. Need rebuild kit? Longer version...started blowing air out of small hole in left side of casing. Leaked oil out of there as well but still worked fine. This has been...
If the trigger still works to fire the single shot, then the o-ring kit should be sufficient. If the trigger area continues to leak air, then the trigger should be replaced as well. Keep the gun well lubricated as well.
Dan
Oct 02, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
I have a bostitch ridge runner that leaks air badly out of the trigger and wondering how to take out the plastic trigger in the gun. Also what would be the cause of the air leak
The air leak can be one of a few things. FIrst make sure that you have added some pneumatic oil to the air stream. This will lubricate the o-rings and make a tight seal. If that fails to resolve it, repalce the o-rings. (kits available for around $20). Next, woul dbe the trigger assembly itself. These triggers wear over time and are easily replaced.
See the website below for parts and a good diagram of the construction of the gun. You should be able to replace the parts by following the diagrams.
http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CO6tkb2y6KICFciA5QodOlL9xg
Please note that the exactmodel number is required to get hte correct diagram.
Hope this helps,
Dan
Jul 12, 2010 | Stanley Factory Reconditioned Bostitch...
Constant air leak
Sounds like you need a repair kit or take to a tool company that installs the kit.
Jun 09, 2009 | Stanley Bostitch Coil Framing Nailer
Flooring nailer tech support
couple of things there are o-rings inside that trigger assy. they are either pintched in or dry. next there could be internal rubber hoses inside the gun. might need replacing. lastly the hose or o-ring going to the back side of the ram is leaking or broken. here is what i would do. you sound pretty handy with your tools so i would get somewhere clean start taking the gun apart thouroghly noting where everything went and go untill you find the problem. but first i would shoot a couple of drops of oil into the air input on the gun then hook it up and fire a few off and see if it clears up, if not then start takeing it apart. I CAN NOT STRESS ENOUGH....DO THIS ON A CLEAN SERFACE WITH YOUR HAND CLEAN. i chased a leak around in a pnumatic hammer for 3 days all because it wasnt clean on the inside..
Oct 13, 2008 | Porter Cable 2" Flooring Cleat Nailer...
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Sep 29, 2008 | Air Tools & Compressors
Stanley Factory Reconditioned Bostitch U/RN46 1 1 3/4" Coil Roofing Nailer Logo
511 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
