Question about Toshiba TEC B SX4T Printer
How do you setup the IP address on a toshiba tec b sx4t printer?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
In diag mode (pause and feed key depressed switch on )
go to ip adress and change the value or use the instructions
{IP;2,xxxx,xxxx,xxxx,xxxx'} for the ip
{IP;3,xxxx,xxxx,xxxx,xxxx'} gateway
{IP;4,xxxx,xxxx,xxxx,xxxx'} subnet mask
socket port
{IS;1,09100'} for socket number and activation
{IS;0,09100'} for deactivation
Posted on Jan 14, 2014
5 Suggested Answers
  • 10 Answers
SOURCE: Network printing issues - Toshiba e-studio 16s
try this:
start, printers and faxes
right click on the print driver , go down to properties click
click on ports
click configure port
click lpr in protocol
Lpr queue name PRINT
LPR byte counting enable
SNMP enabled
Try this and make sure your ip address is correct
Posted on Feb 06, 2008
Muggs01
  • 72 Answers
SOURCE: Just moved IBM 6400 dot matrix. Need new IP address.
it should have kept the same address
Posted on Jan 19, 2009
  • 24 Answers
SOURCE: How to configure internal LAN in B-SX4T barcode printer?
I hope thisis understandable.
  1. Switch printer off
  2. Whilst pressing the [FEED] and [PAUSE] keys, switch the printer on. Display shows D I A G . V 3 . 1
  3. Press [FEED] button 6 TIMES or until the display shows I P A D D R E S S
  4. Press [PAUSE]
  5. Press [PAUSE]. Display shows IP Address
  6. Using the [FEED] and [RESTART] buttons, change the 1st number in the IP address
  7. When you have reached the number you want, press [PAUSE] to step to the 2nd number in the IP address.
  8. Again Using the [FEED] and [RESTART] buttons, change the 2nd number in the IP address
  9. Again when you have reached the number you want, press [PAUSE] to step to the 3rd number in the IP address.
  10. Repeat steps 8 and 9 until you have the 4 digits you want in the IP address.
  11. After the 4th number has been entered and you press [PAUSE] you can change the GATEWAY IP ADDRESS.
  12. Step through the above sequences to get the GATEWAY IP ADDRESS you want.
  13. You'll then move onto the SUBNET MASK IP ADDRESS. Same steps as before.
  14. The next and final item is the SOCKET PORT, enter this 5 digit number as above, stepping through each of the 5 elements that make up the 5 digit number.
Posted on Dec 17, 2010
SOURCE: Toshiba TEC B SX4T Printer when
Hi wgleason0820,
I see that you are having issue with you Printer, you mentioned it is asking for a HEX key but you dont have one.
Instead of having the system set to HEX set it to AHCI then restart the machine and check again this should not aske for any 4 digit HEX passwords anymore.
See Link for details. Link
I hope this can be of Help.
Have a nice day,
mvincentc
Posted on Jun 03, 2011
Toshiba S4X (B-S4XT?); the FEED-PAUSE setup function asks for a password and prompts for 4 digits. 0000, 1234, 9999 don't work. What is it?
You must send a sequence to erase the password.
This is kept secret otherwise it's no use.
Check with your dealer
Sep 06, 2011 | Toshiba TEC B SX4T Printer
I am getting dull print in TEC B-SX4... but i load stock correctly
You may have to realign the print head.
The angle may be different from the original one
Aug 30, 2011 | Toshiba TEC B SX4T Printer
What is the best software to use for the Toshiba BSX4T Printer : with LAN card ? jack boychuk
Use seagull dirver and bartender. A light version is delivered with each printer
Aug 25, 2011 | Toshiba TEC B SX4T Printer
Toshiba BSX4T Printer : installed LAN card : can PING the IP ... CANNOT get the web interface HTTP with browser
To do this you need to add the ata card option with the page loaded
To do that you also need a utility to download the pages to the printer.
Aug 18, 2011 | Toshiba TEC B SX4T Printer
Hello, where are a reseller of toshiba labelprinters type SX4. One of our customers has problems with printing labels. The errormessage on the screen of the labelprinter is: INLINE B-SX4T U5.0 and...
Well at my old company we use to get our's fixed and replaced from toshiba TEC in London.
Campus 300, Spring Way, Maylands Ave Ind Est
Hemel Hempstead, Herts, HP2 7GG
United Kingdom
info@toshibatec-eu.co.uk.
(0)870 890 7200
Aug 17, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
We have a message on the window who is: SG;0121,0-68,002 TOSHIBA B-SX4T C5.7
Communication problems between the printer and the host.
Check the cable or the type of parallel interface selected in the parameters of the printer
Jun 10, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
  4. Press [PAUSE]
May 05, 2010 | Toshiba TEC B SX4T Printer
I am having problems with bar gain issues with Tesco
Tesco prefers 300 dpi printers.
use a bsx5 printer or the bex4t printer
May 20, 2009 | Toshiba TEC B SX4T Printer
356 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
