Water didnt shut off at medium load. overfilled
Water didnt shut off at medium load. overfilled machine. cannot get top of washing machine off to look at problem
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Sonds like faulty pressure swith/ or hole in air pipe feeding switch/or chamber blocked feeding air hose..Good luck
Posted on Sep 30, 2009
Neighbor reports It's overfilling Water on floor.
Could be a faulty water level switch ,or blocked pressure chamber hose leading to switch, or a sticking water inlet valve, question of elmination I'm afraid.
Mar 07, 2010 | Maytag PAV2300 Top Load Washer
Roper washing machine will only run one load every 12 hours!!
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jan 21, 2010 | Washing Machines
Washing machine overfills
Grab the tube off the water level switch that comes from the bottom of the tub and blow it out so that the sand in the bottom won't be blocking the operation,pump out the water, secure the tube tightly to the pressure switch and retry.aff8f03.jpg
Jun 10, 2009 | Washing Machines
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Washer will overfill on small load and large
If this happens only on small load cycle , then it can be a faulty timer board.
however check also the water level switch, when there is overfilling this part is always the first suspect.
May 21, 2009 | Kenmore Elite 21082
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Over filling
pressure switch pipe is either blocked or damaged, the weight of the water pushes air up the pipe to activate the switch to stop the water filling, for some reason its not doing so,
this is a small thin pipe that goes from a point in the machine low down, to a little round flat object (normally) up near the top of the machine inside up near the top
drain the machine and clear out the pipe at the bottom where it joins  the drum or whatever, make sure joints are made good
if i have helped please rate me
Oct 10, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
