Question about Epson LX-300 Matrix Printer
Printer is not running while the power cord is ok.
The printer gives the 3 short sound and after that continuous sound is produced.
    President:
  • 2,049 Answers
Epson says....
Why is the printer beeping three times and the Paper Out light is on?
This indicates that the printer is out of paper. Make sure the paper release lever is in the correct position, then install the paper and try printing.
Q: Why is the printer beeping three times and the Paper Out light is on? A: This indicates that the printer is out of paper. Make sure the paper release lever is in the correct position, then install the paper and try printing.
Posted on Sep 30, 2009
Power won t stay on
1.check outlet to make sure it's ok
2.could be power cord
3.could be connection between power cord and sewing machine
4.could be short in wiring
if it continues, I suggest to have the machine checked
Jan 17, 2014 | Sewing Machines
ASUS KFN4-D16/SAS doesn't start
Hello, I would start with the power box, check to see if you have the right one, if power box works then the only other thing is the motherboard may need to be replaced. make sure you dont have a screw shorting the motherboad out. it sounds like a short on the motherboard.
Dec 23, 2007 | ASUS KFN4-D16/1U Motherboard
0xc18a0001 failure
You could try a power reset of the printer.
Press ON button to turn off printer
Unplug the power cord from the back of the printer
Remove all of the ink cartridges
Wait 3 minutes
Plug the power cord back into the printer
Press the ON button to turn on the printer
Install back all of the cartridges
If this does not work, you could try a hardware reset.
1) Press and hold LEFT ARROW and then press SETUP
Release both buttons
2) Press OK
3) Press & release RIGHT ARROW until LCD reads System Configuration Menu 2
4) Press OK
5) LCD reads Hardware Failure Status: Clear, Press OK to clear
6) Press OK, LCD now reads Cleared, Press Cancel to continue.
7) Press & release CANCEL until the Welcome or Ink System
Failure screen appears on LCD
8) DO NOT PRINT AT THIS STAGE
9) Use POWER button to turn OFF printer
10) Unplug power cord from electrical outlet and from back of printer
11) Wait 1 minute. plug power cord back into outlet first then back into the printer
12)Turn on the printer, Press OK
The printer will start to initiate, do not interrupt.
Dec 31, 2013 | HP Photosmart C6180 All-In-One InkJet...
B&D Electric drill model DR501 Type1: Power cord
Maybe the motor was damaged by the short.
Oct 31, 2013 | Drills
LG 42PQ6000 SCREEN BLANK BUT SOUND OK
Check all component plug In's and also, check that the leading in puts and out puts are corresponding with eachother to both end of receivers. Check for possible loose connections and pinchs threw the wires causing a possible short in the cord, not giving it the full potential it has to produce sound as well as picture. Highly recommend hdmi cords for all connections.
Jul 08, 2011 | Televison & Video
Improper Shutdown Message
1. Disconnect the power cord from back of printer ( while printer is powered on )
2. wait for 10 seconds
3. hold and press the Power button and connect the Power Cord.
4. Release the Power button after 3 seconds
5. Follow the Instructions on the printer screen.
Later try to shutdown it, it should not give the message again
Jun 16, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP PHotosmart c6150 keeps shutting on and off repeating the same meassage improper shutdown.
You need to reset the printer. I had the same exact problem with a C6150. Unplug the power cord from back "while printer power is on" (doesn't have to be fully booted just turning on). Wait 20 seconds, hold # and 6 keys together and plug power back in. Continue to hold until power goes off or semi-reset message comes up. Power up (if off) press OK for any error messages and let the printer cycle. Should be good to go. Mine sounded very noisy while it was trying to allign internally. I can only suspect that was the initial problem but this process fixed mine and it runs great now. Hope this helps.
Jan 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a canon mini260 and its giving me an error 6000
Other than doing a reset, unfortunately your Canon may require repair. By resetting the power, you clear the print buffer and reset certain sensors which may be producing the error.
1) Turn off with power button
2) Unplug data cable
3) Unplug power cord for 10 minutes
Plug power cord back in, reattach the printer data cable and press the power button.
I hope this helps!
Dec 20, 2009 | Canon PIXMA® mini260 InkJet Photo Printer
Got a honda 3 wheeler 200e bigred runs but does not charge bat the stator that runs lights and charging has two wires how do i check it thanks
make the big red running then removed the positif wire on the battery...if lights continue to works then the stator should be ok because it produced energy to make the light on...you will have to check for the voltage regulator that may not redirected any power to the battery....if this test d,idnt work then let me know...i will give you some stator continuity read.
Sep 24, 2009 | 2003 Yamaha YZ 125
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
Epson LX-300 Matrix Printer Logo
237 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
