Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Return spring poulan fl1500e leaf blower failed took it apart and reset it there are two short screws in the bunch need to know where they are placed there doesn't seem to be any thing obvious that is jumping out at me. need exploded view diagram.
  • 472 Answers
THAY GO ON THE LOWER BOTTEM ON THE SIDE FYI IF YOU PUT LITTLE WASHERS BETWEN THE MOTTER AND THE CASE WERE THE 4 BOLTS THAT HOLD THE MOTER TO THE CASE THAT WILL FIX YA UP
Posted on Sep 30, 2009
Oil leak on poulan snow lower
follow this steps and fix it. God bless you
  • Remove the hex bolts holding the plastic leaf blower housing in place with your hex wrench. You may wish to cut the cord with your scissors and loosen the bolt or screw securing the rope assembly with your hex wrench or screwdriver.
  • 2 Remove the spring assembly carefully. Do not remove the spring, only remove the assembly.
  • 3 Remove the old cord from the leaf blower pull cord assembly by gently pulling it away from the assembly with your hands. Notice the direction the pull cord is wound, as this becomes important in the next step.
  • 4 Wind the new pull cord in the same direction you removed it in Step 3. Make sure the inner end of the pull cord secures in the faster or slot provided on the pull cord assembly. This varies depending on the leaf blower manufacturer.
  • 5 Replace the pull cord pulley and place over the spring. This is the white plastic spool.
  • 6 Rotate the pull cord assembly two or three times in the same direction the cord pulls wearing safety goggles and work gloves. Reinsert the center screw by screwing it in place with your screwdriver; this holds the pulley assembly together
  • 7 Insert the leaf blowers cord end into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new pull cord; this prevents the handle from being pulled off the pull cord while you start the leaf blower.
  • 8 Place the pull cord assembly back onto your leaf blower in its designated area and secure by refastening the four hex nuts with your hex wrench.
  • 9 Replace the housing cover of the leaf blower and refasten the hex nuts with your hex wrench. You removed the housing cover in Step 1.
Nov 24, 2013 | Garden
Need to attach starter pull cord on a poulon leaf blower BVM200VS
I had the same problem. I opened up the blower by removing all the Allen screws, 4 mm wrench.
Then pull the motor, need a Torx T-25wrench. You then need to wind up the recoil which is part of the case on the motor side. Wind it up all the way and then put a screw in the slot that is in the recoil.
Thread the cord through the tube through the triangular hole in the white disc. Type a big not that won't slip through the hole. Pull the screw that is holding against the spring.
Remount the motor, wiggling it until it slips into place. Make sure it ratchets.
Reassemble and you shold be good to go. Only took me 3 attempts to get it right.
Oct 01, 2010 | Poulan Garden
Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
May 09, 2010 | Garden
Poulan Pro leaf blower will not start. I need to
Buffalo Creek Small Engine
1054 Teels Branch Rd
Hunington, WV 25708
304-429-4301
This is a repair place Poulan shows for your area.
Good Day.
Oct 26, 2009 | Garden
Rewind a recoil starter spring. I've spent many hours trying to get the recoil spring put back in its place with no luck.
I DID THIS SAME JOB BY WINDING THE SPRING UP IN MY HAND AND THEN TOOK 2 TWIST TIES AND WRAPPED THEM AROUND THE SPRING TO KEEP IT IN THAT CONDITION. I THEN INSTALLED THE SPRING WITH THE LONG END OF THE TWIST TIE EXPOSED AND AFTER GETTING THE ROPE HOUSING IN PLACE I PULLED THE TEWIST TIES OFF WITH SOME NEEDLE NOSE PLIERS. HOPE THIS HELPS
Sep 25, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Moby bladez pull cord spring out how do i assemble it
The only trick to getting this back together is patience and determination. You must keep the spring flat as you wind it tight.
Jim
Jun 09, 2009 | Poulan 12a Elec Blower/Vacuum
GAS LEAF BLOWER WILL NOT START GETTING FIRE
Maybe your carb is out of adjustment. The easiest way to readjust is to turn the screws all the way in and start the blower. While it's running start to back the screws out until it runs nice and smooth and you should be all set.
Apr 30, 2009 | Garden
Putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Oct 10, 2008 | Poulan Featherlite Gas Blower, with Low...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
136 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
