Question about Whirlpool SF310PEK Gas Kitchen Range
Re:Whirlpool SF310PKE gas range
The oven ignitor is red and glowing but oven does not light.
The manual says to push oven temp control knob in and set to 350 degrees and oven will light in 20-40 seconds.
All other burners and clock work o.k.
  • 15 Answers
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Posted on Dec 21, 2007
I just got my oven today. Model # sf114pxsq. Everything worked perfect but my oven would not turn on gas. ie wouldn't light up. We have checked everything from top to bottom. Ignitor is brand new. We solved the problem by locating a little switch in the back. It is located right under the gas regulator(where you plug you gas line into the range) just turn it on. It was turned off in my case.
Posted on Aug 08, 2008
How to light oven pilot
When the oven control knob is in the off position(vertical), turn it counter-clockwise to the next position. This is the oven pilot light. Push the knob down, and while holding down, push the red piezo ignitor button located behind the bottom plate under the oven door. This little door swings open top down, like the oven door. Push the ignitor repeatedly, while holding the knob down. If it doesn't light, or you smell gas, let it dissipate before trying again.
Jun 13, 2014 | Star Tri-Tsr-6 36" Gas Heavy Duty 6 Burner...
It doesn't turn on - no ignitor glow, suddenly
Hi and welcome to FixYa. I am Kelly. Without a model number we are pretty much shooting from the hip here. Having said that it takes all of the following to make the oven burner light:
1. Gas pressure to the gas valve and good solenoids (2 ea)
2. Power to Oven control and selector knob set above min temp
3. Over Temp sensor closed
4. Temp control "thermocouple or thermistor" functional
5. A functioning ignitor
So if you have power to the unit... and we assume the oven control is working.. suspects are:
a. Open ignitor
b. Open flame sensor
c. Open over temp sensor
d. Thermocouple or thermistor (depending on model)
e. Open coil on gas valve
Determining which of the above has failed is performed with an Ohm Meter.
If there is more that we can do for you just respond here.
Thanks for using FixYa.
Kelly
Apr 02, 2010 | Magic Chef 9122 Gas Single Oven
The oven does not heat up, the igniter glows orange but the oven does not light. It is a whirlpool accubake gas slide in range
Hi, You will need to change the ignitor.
Even tho it is glowing, it is going bad and isn't strong enough to open the gas valve.
It is very common problem. Remove the floor panel in the oven and you will be able to see the ignitor.
Make sure the oven is unplugged while changing the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vid
Jun 13, 2009 | Kitchen Ranges
Whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
Vic
May 27, 2009 | Whirlpool GS445LELS Gas Kitchen Range
Gas oven not keeping temp consistant
Hi. this is a failing oven temp sensor. the sensor probe is not responding to the oven control. this will cause erratic temps in this oven. it will also damage the control board if the sensor isn't replaced soon.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
WHIRL POOL OVEN BURNER WILL NOT IGNITE
the porcelain always remains white its the glow bar toward the end that will glow, you will need to check for power leading the ignitor, if indedd you have 110v, there replace ignitor very common issue with gas ranges
Nov 20, 2008 | Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool SF310PEK Gas Kitchen Range Logo
279 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
