Question about KitchenAid KGRA806PSS Gas Kitchen Range
Hi,I have a kitchenaid gas stove and the oven does notwant to heat up. I have it on now for 20min,just barely warm.Any suggestions?
  • KitchenAid Master
  • 3,361 Answers
Most likely a bad glow bar ignitor at the oven valve. It must read 3 amps or more to activate the gas valve. Turn the gas off,put a clamp on amp meter on the ignitor wire and turn the oven on. If it reads less than 3 amps,replace the ignitor.
Posted on Sep 30, 2009
Kitchenaid oven troubleshooting
it sounds like the heat escaping from the door damaged the electronic control board part number 8186393 and sears has it for 200 dollars.the way the door was left open was directing the heat right at the computer board and you sholud never use the stove for heating the room or things like this happen
Nov 20, 2011 | Kitchen Ranges
Im having a problem with getting my oven to heat....so its not baking or heating in any sense. I've continuously unplugged the stove and attempted to get it heated but it still never gets warm or anything....
Hello and sorry to hear about your problem.
It sounds like your oven glow rod, is defective. This is the electronic pilot lite for the unit.
I suggest you can in a service person. If you live in the Denver Co area, I can help you.
I have tried to help you. Please help me by Vote/Rate this response. Thanks and good luck.
cvbb
cvbcb
Dec 23, 2010 | KitchenAid KGRS807SSS Gas Kitchen Range
Hi! My old school Admiral oven/stove top is having issues. I rent, so I don't want to bother my landlord until I have to - or know what to tell him. Basically, it won't heat anything substantially. The...
You need to contact the landlord and I will tell you why: The stove should not have issues above and below simultaneously. I comment you for not wanting to bother the landlord but I feel like you have an electrical problem. The oven not there and the top not there? You have a bad circuit breaker on that puppy. Takes a 50 amp 2 pole 240 volt breaker for an electric stove and only qualified schocktricians should fool with them. My opinion.
Nov 30, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
KESC307 Electric Kitchen Range: The oven doesn't work, stove works....
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | KitchenAid KESC307 Electric Kitchen Range
My stove does not maintain a consistent
This is most common with electric ovens and the bottom element goning bad...but I will also include the most common problem for gas ovens also when this happens, as you did not specify which you have...
If you have a gas oven...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 04, 2010 | Kitchen Ranges
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
I'm looking at a KitchenAide KDDT207B duel-fuel used stove to purchase used from a private party I don't know. Are there reliability concerns?
I have this same oven. It began to intermittently fail when using the oven. The error code suggested it was a problem with the keypad. I suspected it was because the electronics was overheating. The electronics for this model is approximately underneath the right front gas top range. What I found was that the failure occured when both the oven and the right front gas range were being used simultaneously. This caused overheating since the electronics has not fan in this model and the heat radiating down from the pan above the gas range is added to the heat coming from the oven below. The electronics is sandwiched between these two heat sources.
Nov 16, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Montgomery ward gas stove. top burners work fine. oven barely gets warm
I have a whirlpool gas stove oven fire will not go off when in off position. Is the fire suppose to go off completely?
Aug 21, 2009 | GE JGRS14 Gas Single Oven
Whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Whirlpool GS445LELS Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
251 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
