Question about Kodak I620 SHTFEDSCAN Path-Through Scanner
Have a Kodak I620, it feeds the first page through and it stops as it is coming out and the next page stops as it enters the fuser area, then receive a red light on control panel. Please advise
  • Steve Dyer
    Steve Dyer May 11, 2010
    Wants the error code..sounds like ultrasonic problem.
    New Friend:
Cleaning or change the feeder clutch.. and cleaning UDDS sensor
Posted on Jan 22, 2013
3 Suggested Answers
  • 3 Answers
SOURCE: i620-auto feeding multiple sheet
You have to change the lower Sep. Roller Assy.
Posted on Feb 04, 2009
  • 16 Answers
SOURCE: i have a Kodak i620 color. All of a sudden the red
What does the KDS Log say? find it in the SVT info tab and save it for more info. its probably your ultrasonic sensors dirty or faulty. good luck
Posted on Sep 24, 2009
Every page has 3 or 4 black dots right down the center. How do I get rid of these?
Are the spots the same on every page?
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
If it is the drum area:
Clean the loose toner up with a dry lint free cloth.
If it is the fuser, it may have a bad spot and would need to be replaced.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 28, 2011 | Digital Products Brother HL-2040 Laser...
There is a smudged side on the fax when it comes across. I have changed the toner and shaken the toner up the smudge still comes back in the same place on the fax
If this smudge is showing up on the faxes you are RECEIVING and you have changed the toner then the next most likely cause is a fuser problem. This is especially true if the smudged area feels gritty or the toner rubs off the page in the smudged area. If this is the case then you need to replace the fusing unit or have a local repair place replace the fuser "film" on your fuser unit.
Good Luck and Thank You for using Fixya.
May 11, 2011 | Canon FAXPHONE L170 Plain Paper Laser
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
HP 3050 vertical black lines during fax
OK, from the desciption i can assume several things here are some option.
If by receipt you are talking about the confirmation the unit prints the the problem is likely dirty glass.
You would also get the lines when you make a copy using the ADF.
Open the lid there are two areas of glass the thin strip is likely dirty and needs to be cleaned.
If by receipt you mean pages you receive from someone else, and not printed or copied on your machine, then their machine has the condition described above.
If everything has the lines then you have a toner or fuser problem:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 24, 2009 | HP LaserJet 3050 All-In-One Printer
I620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
Nov 07, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
I620-auto feeding multiple sheet
I opened the hood on the machine, and between the first two intake rollers on the bottom, there is a small rubber strip. This strip comes packaged with a sticky yellow tape to protect the rubber. When it was installed, no one removed this tape. After doing so, the machine feeds great. Hope this helps someone else who may be experiencing a similar feed issue.
Jul 16, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
LJ3700 page tops half- way through fuser. Bob
13.01.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. 13.02.00 (HP 3500) 13.20.00 (HP 3700) Description A media delay jam has occurred in the registration area. Action Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing. these are areas that you mentioned and fixes to them http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3 this is the link to all error codes for your printer you might want to print these out and keep safe
May 07, 2008 | HP Color LaserJet 3500 Printer
Recurrent paper jam
well, i hate to admit this, but we never solved it. for the C762N we had in our shop, we're assuming the frame is tweaked just a bit (the machine i was working on had some damaged lower plastics, probably from a small 1 foot drop or so).
best of luck.
chris
Apr 03, 2008 | Lexmark C762 Laser Printer
Brush roller lines in feed direction of pages
Maybe the charge roller. Make sure it is very clean. You can also stop a copy before it enters the fuser to rule the fuser rollers out.
Feb 08, 2008 | Panasonic Workio DP-2330 Printer
Kodak I620 SHTFEDSCAN Path-Through Scanner Logo
157 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
