Question about HP Compaq Presario F730US Notebook
Compaq f730 wireless just quit - orange light stays on
The computer won't do anything "wireless" - it won't access the wireless assistant, installed a external USB adapter and still no wireless. Now, I can't even uninstall the adapter.
  • 3 Answers
One of the simplest things to do if you have this problem is uninstall the HP wireless assistant and re-install it from the HP website. Try the link http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=ob-48908-1&cc=us&lc=en&dlc=en I had the same problem. My wireless suddenly stopped working and the LED indicator for wireless stayed orange no matter what. HP wireless assistant refused to start from any location. I tried updating the drivers, using a system restore from a restore point and what not. I found this solution somewhere online and did it. It miraculously worked for me. Please let me know if this solution helped you.
Posted on Oct 28, 2009
Just uninstall hardware then load drivers a fresh
Posted on Sep 30, 2009
Wireless on laptop not working
get the drivers from the manufactures web site under support, then select your make & model.
it should be in device manager under network devices once you've got it installed.
DRIVERS LINK:
Jan 30, 2012 | Computers & Internet
Hi there! I would like to know how to unlock internet button from my HP probook. Its button light is orange and I have no access to the internet. I'll glad you anything you can do for me! ...
Not knowing the model of your unit, I respond with a general answer:
Using the wireless controls
You can control the wireless devices in your computer using these features:
?? Wireless button
?? Wireless Assistant software (select models only)
?? HP Connection Manager software (select models only)
?? Operating system controls
Using the wireless button
The computer has a wireless button, one or more wireless devices, and two wireless lights. All of the
wireless devices on your computer are enabled at the factory, so the wireless light is on (blue) when
you turn on the computer.
The wireless light indicates the overall power state of your wireless devices, not the status of individual
devices. If the wireless light is blue, at least one wireless device is on. If the wireless light is amber, all
wireless devices are off.
Because the wireless devices are enabled at the factory, you can use the wireless button to turn on or
turn off the wireless devices simultaneously. Individual wireless devices can be controlled through
Wireless Assistant software (select models only) or through Computer Setup.
check chap.2, page 22 in this manual:
http://tinyurl.com/3czcyss
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks,
Joe Diaz, Nashville TN.
De Cayey, P.R.!!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 20, 2011 | Computers & Internet
My wireless assistant has stopped working and the light stays orange
I had the exact same problem...and the wireless adapter was not visible under device manager. The light stayed orange with the switch in either the on or off position. I did all the whole driver update thing and eventually replaced the wireless adapter but no change. Finally I went into the BIOS (F10 on startup) and reset the bios configuration to the default settings EXIT>LOAD SETUP DEFAULTS). It has worked perfectly ever since.
Sep 03, 2010 | HP Compaq Presario F500 F700 and G6000...
The "wireless on" light will not go from red to blue
Try this :
1.Download the latest wireless driver for computer (7.20 REV:A, 2/20/09) - Might change depending on your CPU, (7.20 REV:A is for AMDs)
2.You will also need to download the latest Bios (F.42, 3/9/09)
3.Latest version of HP Wireless Assistant (3.00 REV:K, June 2009)
NOW YOUR READY TO START FIXING?????
INSTALL STEPS: You must use this order for an 100% fix
1.First flash your computer with the latest BIOS and if should restart after its complete.
2.Install the wireless driver
3.Install HP Wireless Assistant
4.Restart your computer
5.Flash Bios again
6FIX
Apr 20, 2010 | HP Compaq Presario V2000 Notebook
Wireless is not working light is on but orange. even wireless usb adapter will not work
I would start by installing the drivers first, and then restarting the computer. Make sure that all computers in the same network are having access to the internet, if they do, it's absolutely the wireless driver.
If that also doesn't help, it is possible that the card has a malfunction. Try also plugging the laptop to a wired connection to the internet. Again, if that works, it means that you should install the driver again
Dec 07, 2009 | HP Compaq Presario F730US Notebook
Installed new hardrive on our Compaq laptop, question
Hi there.
Just make sure the boot order is set to the CD/DVD, you can do this by going into the bios or pressing F12 while the computer starts up.
please post back if you need any more assistance.
Regards
Jun 01, 2009 | HP Compaq Presario F730US Notebook
HP Wireless assistant not working, light staying orange
Window Vista- Go To Control Panel, then go to Mobile PC, then Window Mobility Center, then go to the top right of the mobility center and click on Turn Wireless On
May 27, 2009 | Microsoft Windows Vista Home Premium...
Sir i format my laptop compaq model number presario f700 i want free download of audio driver setup
If you’ve installed Windows XP on Compaq Presario F700 or Presario F730 follow this simple step:
a. Install Microsoft UAA
 http://tinyurl.com/6kelwb
then reboot your computers
b. then install Conenxant Audio Sound Driver
 ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34386.exe
Jan 24, 2009 | Compaq Creative Sound Blaster PCI 128...
HP Compaq Presario F730US Notebook Logo
1,742 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
