Question about Cuisinart DCC-1200 Coffee Maker
When brewing the water the coffee maker makes a bubbling sound, like it would towards the end. Brewing takes longer then it should
  • 708 Answers
Pull the water line off and make sure its not clogged up.
Posted on Sep 30, 2009
  • philip griffin
    philip griffin Jun 29, 2014
    Where is the water line?
How do i clean the water chamber
Well I use vinegar. Fill the water chamber with 1 cup vinegar and water. Run through a brew cycle. Than run through again with plain water.
Jul 18, 2015 | Coffee Makers & Espresso Machines
Cuisinart dgb-650
In an empty machine,(no coffee, no filter), pour in a 50-50 mixture of water and white vinegar. Allow the machine to start brewing and when a cup or so has run through, stop the brewing process and let it sit for an hour or two. This should dissolve some of calcium buildup in the machine and allow it to complete a full cycle. May have to do this a couple of times to fully clean out the mineral buildup. After cleaning, run a pot of clear water through to rinse out the remaining vinegar.
Dec 03, 2017 | Cuisinart Coffee Makers & Espresso...
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Slow brewing
The coffee maker has three contributory factors for brewing experiences. First, putting enough water in container prior to brewing is expected to dispense in to coffee capture cup. Second, installing the component parts after inserting coffee leaflets should not hinder brew seepage into the cup. Third, allowing enough time for the brew to dispense is a requisite means to coffee impressions. Furth, coffee leaflets require appropiate numbers inserted at the container area lest the machine takes time to sock and dispense. However, refer to the device user guide for appropiate manufacturers instructures to user as expectations during brewing. Also, refer to the user guide to ascertain any conditions that may be signs of damage preventing fast brewing.
Jan 22, 2011 | Oster HDX23 12-Cup Coffee Maker
My keurig will not brew. It says it is brewing but the water level is not going down and it is not brewing
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Nov 11, 2010 | Keurig B60 Coffee Maker
No water coming out makes noise and slite water and its not hot
Use vinegar as water and soak over night. Use the same vinegar as water the next day as if brewing coffee. Then use fresh vinegar as if brewing coffee. Next use water several times until you don't smell the vinegar. Now try brewing a pot of coffee. good luck.
May 12, 2010 | Keurig Elite B40 Coffee Maker
Why does the coffee maker make a loud noise right before it brews the coffee?
Usually this is the expansion of steam as the heating element quickly rises to the preset temperature. This process heats the water to the correct temperature and causes the water to flow upward from the water reservoir. Then out the brewing spout over the coffee grounds.
It will usually make strange noises at the end of this cycle too.
The water is used up and remaining steam is vented.
Sounds more like a burping and last minute gurgle really. :)
Hope this helps!
Nov 17, 2009 | Keurig B100 Coffee Maker
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Leaking water
Take out the brewing unit and look in the chassis behind where the brewing unit was, you will see a little hole, put in your finger and make sure the hole is clean.
Have a nice day
/Mirran
Oct 20, 2008 | Saeco Vienna SuperAutomatica Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
768 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
