Question about Intermec EasyCoder 3240 Printer
How do i replace a platen roller on an intermec 3240
The roller does not hold paper tight so will not roll or advance
on either end the platen roller has collars, some you can sqeeze and lift the roller out.some have release and turn type mechanism. under the platen roller there are several smaller rollers . 6 to 8. inspect this area for foreign debris. clean with 70% alcohol. reseat the platen roller and test.Platen will lock in if not its in that latch.the worst case is you have a broken gear.
Jul 24, 2015 | Brother Ml-100 Electronic Typewriter -...
Platen roller is slipping
If this is a mastertype 3 the platen knob probably needs replaced. We have themin stock 15.00 includes shipping
**** O'Reilly
216-269=3918
Sep 30, 2012 | Olympia Mastertype 3 Typewriter
How do you replace the platenroller guide rollers?
to replace the feed rollers under the platen. 1 - remove the platen by squeezing the black plastic clips at the ends of the platen and pulling the platen straight up. 2 - pull the paper pan out, 3 - push down on the feed roller set and rotate it towards you. replace bad rollers and put things back in reverse order. there is a guide on the rod the feed roller unit sits on, make sure the guide on the feed roller unit goes back in this. there are pins at the right side and left side of the right and left feed roller units. these are for positioning the paper pan in the slotted tabs on the bottom of the paper pan. make sure the gear on the platen goes on the left side, position the clips to center on the frame, then push straight down. make sure both clip are fastened in. the only reason you should be replacing these rollers is if they are splitting apart or falling off due to the pins at the ends of the rollers wearing off (never seen this happen on a WW6) if you are having some sort of other problem, you might ask for a different solution before doing this - its harder than it sounds.
Dec 20, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
In typing a label, it got stuck on the roller and the daisy wheel. The only wat to remove the label was to remove the roller. I did that and replaced the roller. Now the daisy wheel is only printing part...
The platen (roller) is not fully seated in the side frames check to be sure the latches are lined up then press firmly on both ends of the platen it should snap into place.
DickyO
Dec 22, 2009 | Lexmark Wheelwriter 15 Series II...
Z4Mplus has a worn/cut platen roller
did you try to find info at manufacrturers website or email them?
Jul 06, 2009 | Zebra Z4M Printer
Label not printing
Firstly, check your software settings, sometimes you need to reduce the print speed a bit, and turn the darkness up... if there is a knob for print head pressure adjustment, turn it up! i'd also clean the head and platen roller with isopropyl alcohol, failing all of the above, contact your media supplier and check that you have the correct media combination. hope this is of help to you, Markus.ps Failing that ...if you need a trained intermec engineer....... contact Precision Peripherals.... jrichards@printer-service.co.uk
Jan 23, 2009 | Intermec EasyCoder PM4i Printer
Replace S4M Platen Roller
Call Brian at Peak Technologies for the platen roller 877-863-2522 xt. 6807
Jan 09, 2008 | Zebra S4M Thermal Label Printer
Intermec EasyCoder 3240 Printer Logo
347 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
