Question about Whirlpool Kitchen Ranges
How do I replace a burner control on a Whirlpool glass cooktop model GJD3044RB00? I know the control is bad, because the shaft came out of the control [left front]
    President:
  • 1,489 Answers
Turn off circuit breaker to range. Remove the cooktop from the cabinet and tilt it to give access to the control. Remove the nut on the top holding the control in. Diagram wire connections, disconnect wires, install new control, connect wires to new control, put cooktop back into cabinet.
May need to prop up cooktop in tilt position to keep it in place while you work on it.
If you have trouble/question, let me know.
Charlie
Posted on Sep 30, 2009
My jenn-air 8430 cooktop left front burner cycles off-on in the HIGH position. What could be wrong?
I am assuming your cooktop is electric and your have a glass top, if so the burners sensor is bad and you might need to replace the burner. Again before buying anything and for me to help you, I would need a full model number. Some model have plate sensors and with no plate/pot burner cycles. Most of the time I find the sensor in the burner cant detect the heat and this ends up being a safety issue to protect the unit. All this information is based on the premise you have an electric cooktop and a glass surface.
I hope this helps.
Oct 16, 2013 | Jenn-Air Cooktops
We have a whirlpool gas cooktop, Model SC8720EDB, Serial FMG1005626. When the left two side burners are lit, either one or both, the suction fan automatically cuts on. When the right side burners are...
It does this by design. It is a safety feature on this model because it was designed to have a gill module on the left side. I don't know if you can change it without replacing the two left control valves with valves like it has on the right burners.
Nov 24, 2010 | Whirlpool 30 in. SC8720 Gas Cooktop
Have whirlpool glass cooktop,, the heat indicator light is staying on even though the burner has cooled off completely
This is usually one of the switches has failed. You will need to uninstall and disassemble to acess the switches. They are easy to check and replace. Here is a link that should help http://appliancehelponline.com/infiniteswitchvideo.html You can also enter your model # for diagrams and illustrations of your specific model.
Sep 03, 2010 | Whirlpool Cooktops
Burner out in whirpool black glass cooktop
take the whole cooktop out there should be screws around the base you take them out, seperate the bottom from the glass you should be able to get to the element to check if it is bad by ohming it out
May 01, 2009 | Cooktops
Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
Jan 18, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Replace burner seals of gas cooktop
good day,
hope this link below will solve your problem.
kitchen
Sep 03, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Kitchen Ranges Logo
180 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
